Perkasa F.P.B.
Iniciado por roversean
1 reply 0 gostos 0 seguidores Última atividade: há 18 anos
Perkasa F.P.B.
I have put a 50 twin bladed prop on the same setup but you need to
water cool this setup it seemas to work for me I put two 9.6v
packs in parallel it cuts down on weight the twelve volt batterys are a bit bit on the heavy side and dear side
hope this helps
Perkasa F.P.B.
HI
I have a wooden kit of a 39" perkasa fpb,I have a Torpedo 850 motor for It,but I am wondering what size prop and rudder I need for It,it Is single screw and I am not worried about scale apperance hopefully It will go on the plane.It Is the Precedent kit.
Many thanks Sean
