Does anybody recognise this?
Iniciado por peewit
14 replies 16 gostos Última atividade: há 5 anos
#15 1
I have the Sarik plans for the GB fishing boat and also the glass hull. The deck has a pronounced step and the stern is almost square with rounded corners. The profile looks about right.
This plan ws drawn by LR Armstrong and he according to article liked using old floor boards B & B and a piece of steel as the keel weight.
There should be about 8 Dory boats on board which did the line fishing and space to store them. If you want scale info then the cheapest way is to buy the film "Captains Couragious" with Spencer Tracy.
The middle part of the film is filmed on the fishing boats on-deck and below and there are often half a dozen in view for the shots at sea.
The heavy seas shots and the race are pretty good.
The start of the film is a bit heavy going but sets up the selfish/over privileged character of the lad who gets picked up by a fishing boat.
regards
Gostado por dave976
#14 1
It’s not going to be particularly difficult to restore but their are going to be a few “why the hell would you do it like that” comments made as I do it.
Gostado por dave976
#13 1
I recon probably 1960s
Looking at the build I would recon the chap was probably into bigger woodworking. The hull is very well made but the “fiddly bits” not so well.
I have already scraped of, sanded down and given the deck it’s first coat of satin yatch varnish. I think my target is go get it sailing for a brief outing to Woodbridge model boat pond on Boxing Day.
Gostado por dave976
#12 1
Maybe there weren't any plans, perhaps the builder just built her. That wouldn't have been unusual in the days of bread and butter construction. I remember it well, I'm afraid. There were many builders of traditional working craft that just built there vessels 'by eye' and they invariably worked out perfectly well. Just think, if you don't build to a plan, you can alter things as you progress.
Nerys
Gostado por dave976 and peewit and
#11 1
Hi Smiffy
From your further description this sounds very typical of a 1960's or earlier build when bread and butter was more common and Cascamite was very much in favour. My early pond yacht from this period also used lots of hooks to mount the mast.
I have some early Model Maker and Model Boat mags and they may contain some info, but it may take time. It was popular at that time for a modeller to see a pic and make a best guess copy in which case plans may not be available.
Maybe some of our members over the pond will be able to help?
I look forward to seeing how you progress
Gostado por Colin H and peewit
#10 1
As I mentioned in an earlier post Sarik Hobbies have a plan for the Grand Banks schooner but buying plans to see if they match could get expensive! I seem to recall that there was also a kit available for this particular vessel many years ago in the 20th Century or is that just an old man’s imagination 🤔. Anyway, best of luck with what sounds like a tricky restoration
Gostado por peewit
#9 1
Hi,
It’s definitely a Grand Banks but what I am trying to find out is if it was built from any particular plan. The hull has been well carved and is bread and butter and the deck planked with pine ?
Hull length 34 inches.
The builder definitely liked cascamite wood glue because it’s all over the place and they didn’t wipe it of.
The masts and how they fit to the deck is - well odd and the rigging is mental; hooks everywhere and a lot of them in the wrong places.
Sails are made from kite material, very light and serviceable but looks a bit naf close up.
I will post more as I chip away the glue.
I may put radio in it but initially will probably set it up for free sailing as well as I want to see how it sails first.
I like schooners both old and new and have three or four. I introduced fast free sailing class A schooners to the Southwold Free sailing regattas about 20 years ago. 27 inches long, three pounds all up weight 2 pounds of which was in the bulb keel on a Victorian split keel 14 inches down.
I attach a photo just taken from a picture on the wall of gelt
Which wone the A class championships at Southwold.
Gostado por Nerys
#8 1
Yes definitely a Schooner and looks to be well made. Are you intending to fit RC or try and free sail? We sail several 5' model schooners at my club- pic attached
#7 1
Hi I agree with Smiffy it looks like a Grand Banks fishing schooner. Also the sails look very good, which suggests a well built model.
regrds
Gostado por Morant and dave976
Hi shipmates ... does any one know were I can get scale stansions fo a 47 inch Watson lifeboat ... thanks
Thanks for that. I had a look at their site but as you say the pictures are not great. I think you may be right on it.
It’s not the same size but I have scaled down a Prospero in the past.
Gostado por dave976
It is on the Sarik website although the pictures aren’t great but the Hull is quite a distinctive shape and definitely very similar - I have the advantage of a couple of copies of the Plans Handbooks from the 20th century with better illustrations!
Gostado por dave976
I agree about the rig just not to sure about the hull. Thanks, I will try to get a look at the plan.
At first glance it looks like the Grand Banks Schooner (plan no. MM962 from Sarik Hobbies) - at least the rig looks correct for that.
Gostado por dave976
I picked this up at an auction on Monday really cheep.
Free sail with bread and butter construction. All the ringing cords need replacing as they are very fragile and I need to sand of a lot of blue on the deck but apart from that it’s ok.
It could be a one off but I wonder if anybody recognises it. A rather odd desighn with a lot of tumble home.
Gostado por dave976
