Liverpool Class Lifeboat
Iniciado por Rockbag
9 replies 3 gostos Última atividade: há 5 anos
Looking for plans to build happy to cover cost
I have been in touch with Sarik Hobbies and they do the plans and fibreglass hull for the Liverpool Class Lifeboat for £100.
IJP
Thank you for that information I will certainly look into your suggestions.
Ian (Rockbag)
IJP
Hi again also seem to remember MAP plans handbook had set of drawings , i think all now held by Sarick hobbies , maybe another members knows more ?
Gostado por Rockbag
HI, i believe Metcalf mouldings have not long released a kit of the Liverpool class, you may be aware they did two distinct types, single or twin screw, the single screw ones had mast sails and drop plates if that was the early single screw boats or all i cannot say. Are you aware of the lifeboat enthusiast's ? join up at www.lifeboatenthusiasts.com, 4 comics a year and more info about past and present boats than you can shake a model boat at, regards Deepriverman
Gostado por Rockbag
Thanks for that information my friend I will follow up your suggestion. Ian (Rockbag)
IJP
Ian
Only just found out Speedline no Longer exists, however,
I think there may be a blog by Skydive130 on a Shannon Class that will give you a lot of information.
Austin
AustinG
Gostado por Rockbag
You should try speedlinemodel.weebly.com they seem to have a lot of info and models.
AustinG
AustinG
In 2022 I’m hoping to build a Liverpool Class Lifeboat. Does anyone know if plans are available or maybe a suitable kit?
Kind Regards,
Ian (Rockbag)
IJP
