Buck converter
Iniciado por NickD
3 replies 7 gostos Última atividade: há 4 anos
Buck converter
I wud say that it wud be cheaper just to buy the higher-voltage LIPO battery
VA3ROD
Gostado por River Rat
Buck converter
As River Rat has said you need a boost converter. That said the raised voltage will not have a current capacity of 5.5 amps. Just had a quick look on line and there are some that claim 4 amp max but I would not like to try using it at that level. On Amazon "Boost Converter Module XL6009E1 DC to DC 3-32 V to 5-35 V Output Voltage Adjustable Step-up Circuit Board". I would be happy running it at say 2amps for auxiliary items.
Gostado por RodC and Len1 and
Buck converter
You need a boost converter. A buck converter steps down voltage. 👍
Gostado por fireboat
Buck converter
OK Guys can I use a buck converter to up the voltage with a 5500 50 2s Lipo battery......7.4v up to 12v
