Use Tamiya white putty on RC boat abs/styrene hull
Seguidores (4)
- stotty1111Gold
The only thing I don't like about the Tamiya putty is that his it has a high shrinkage factor. So, when applying you need to use multiple layers with the final layer being a slight convex shape so it can be sanded down flush.
I always use 2 component epoxy
But a friend of mine is using the sprayable filler from MOTIP
Which you can buy in car shops
Herman lifeboat lover
Is it going to be effected by the water? Of course I will be priming and painting/sealing over any areas.
I could use a two part epoxy putty but it is a pain to sand down for just some small imperfections.
Thanks
Gostado por
A carregar…
