Motor and esc
Seguidores (9)
- GregHiltzGold
- NickthesteamSilver
- roycvBronze
- Stephen TGold
Motor and esc
It all hinges around the brushes and the voltage drop. It is simple arithmetic, will explain if interested!
regards
Motor and esc
Motor and esc
I do have a large stock of Model Boat fittings, power and R/C equipment, and building supplies.
I am located in New Brunswick, Canada.
Motor and esc
Context question
Motor and esc
Motor and esc
After much testing, the smoke was coming from the motor but suspected old esc which proved to be OK. I had a spare BL marine motor so fitted that. But there was a mis-match of RC crystals as well.
I am on 27Mhtz I call it staying in character, others know I am reluctant to throw away perfectly good but dated equipment.
So coffee and a sit down while I get my eyesight back to normal.
regards
Motor and esc
When I think about it my old Hectoperm, long gone now, was more than 4 inches long and bigger altogether.
The Decaperm in my hand now, has 4 slotted holes each side and the pictured one has 5, interesting!
The text is DECAPERM in capitols with 6V under but central and below that max 7A
regards to all.
Motor and esc
Motor and esc
Motor and esc
They all had a family likeness, used to be orange and black, then went to all plastic and just grey.
The smaller motors often appeared in 'servos'. But these servos were really actuators from pre proportional days. Then an actuator might be clockwork or rubber driven.
All back in the day as they say.
Motor and esc
There are several versions of these motors right back to when the series of motors were orange and black.
I agree with the comment of being reliable though.
On the 3rd. original photo there are 5 mounting holes which does suggest the Hectoperm motor.
When the Hectoperm motor was last on sale it was £163 not a realistic price at all.
Motor and esc
Motor and esc
Looks good,and has a lot of potential for you 👍👍
Bill
Motor and esc
The boat is based on London Tugboat SunXX11
I tried taking a pic of the inside as to me it looks like it's been carved from a block of wood and is quite heavy with a tiny bit of lead on the sturn
Motor and esc
Motor and esc
Motor and esc
I have been using Marx decaperm en hectoperm motors in all my boats and they are just FANTASTIC
Never ever had any trouble with them
Motor and esc
The motor is a geared Deccaperm. There were 6v and 12v versions and your motor has had the voltage erased so you will have to try with both sized batteries to see which best suits your model and motor. The Esc is I suspect a 12v max 15 amp and not known for their reliability especially if used to their max rating.
Judging by the wooden tray behind the motor an SLA was probably used and my guess would be 6v 10amp.
In the 1960's and 70's the Deccaperm motors were possibly the best and certainly the most expensive motors available. They are however very early versions using technology available at the time. Modern motors use much more powerful magnetic material and modern construction techniques produce much greater power than was previously possible. The Deccaperm had a very good if noisy gearbox which greatly improved the output power of the motor.
Chances are the motor and Esc will work fine and as long as the shaft is oiled/greased and free running you could be afloat in no time.
Plank on frame can be prone to leaking, especially if they have been stored for some years, so I suggest you float in water for several hours to find any leaks before you submit to the local lake.
In its present form it is certainly a classic of its time and it would be a pity to replace the original set up for a more modern system if it is all still functional.
Looking forward to hearing how you progress.
Motor and esc
Motor and esc
The ESC is very much like the one that I have, and that runs on 7.2 to 12 volt, as for the motor it could be a Decapum (sorry for the spelling) a very good motor.
Fred
Motor and esc
Yesterday I acquired an old bread and butter sun tug but question is Does the motor and esc run on 6v or 12v..
I've only ever seen one of these geared motors on a picture and as for the esc no idea.
Regards Terry.
Gostado por
A carregar…
