Fred
XT60 CONNECTORS
Seguidores (11)
Fred
A warning about flux paste, some are highly corrosive and if not properly cleaned will cause oxidation over time. I use rosin pens or rosin cored solder
I use XT60 in all my builds and have changed some of those in my bought models, unless they have Deans, where I use a XT60/Deans connector (bought from e.g. Component Shop) where I have XT60 on the battery.
I use Alloy 63/37 solder, which I don't know the melting point of off-hand but I have the soldering station set at 390 degrees. I use the same method as ALR58 and haven't had any problems with damaging the connectors etc. Tinning the pockets, maintaining the heat and inserting the cables in one operation means that the amount of time the heat is applied is no more than necessary.
I made a pin extraction tool out of some copper tubing. It slides down over the pin compressing the retaining tabs inward thus releasing the pin.
Don't remember what batteries the black Tamiya connector came from. The Batteries went bad but like everything else I kept the connectors in my RC connections drawer. The housing and assembly is completely different by it mates with the Tamiya connector. Lift the little tabs on both sides and the connector comes apart. It looks like the wires are pushed through the back and soldered to a metal contact. When the housing is pushed back together the wired tab contacts a tab on the back side of the pin for a solderless connection. Nice design but I can't find these anywhere.
So for now I'm going to stick with the Tamiya connectors and make repairs if and when needed. Hopefully, not to often.
Any thoughts? I use Pb solder so temp at 347C.
I got mine off AliExpress. along with a tool to hold them in when I soldering them up.
XT60 CONNECTORS
Long time ago, I came to the same conclusion tan most mates, and I settled on XT-60. I use them whenever supply voltage is between 6 and 24 V, including my radio gear (I’m also a ham radio operator and tinkerer)
However, soldering them was not easy at first. After spoiling some of them, I came to the same procedure recommended by jonhnf and others:
1.- Always solder connectors mated. I've found pretty convenient to hold them in a mini vise.
2.- I always use 60Pb/40Sn solder, with 3-3.5% core rosin flux. I do a lot of electronics tinkering, including SMD hand soldering, and I never use Pb-free solder.
3.- I first tin the wire, and check that the tinned end fits in the pocket.
4.-Then I tin the pocket. When solder is melted, I quickly insert the tinned end of the wire while keeping the soldering iron in in good contact with wire and pocket. If you feel that there is not enough solder, add more.
5.- Apply some traction to the wire when the joint is cool. Sometimes you get a “dry joint” if not enough heat was applied.
6.- Repeat the same procedure with the other wire.
A closing note: Currently, I settled on subtype XT60-H. No need to deal with heath-shrink tube, resulting in a neater job!
Good luck!
XT60 CONNECTORS
I hav been a devotee of WELLER soldering irons since age 18(now 75yo). I recently bought a WELLER iron on Amazon which has an adjustable power knob & with the correct solder it handles large joints just fine. The identical iron aimed at the Canadian market the model # ends in CUL which is certified for use in Canada & its 3x the price of the USA/MEX unit
XT60 CONNECTORS
About the soldering irons, the more expensive ones seems to have a higher quality metal tip on the iron. I see no deterioration at all. The "cheap-O's" tips don't last long and seem to build up a coating that does not transfer heat well unless scraped or cleaned. This possibly could be the problem with melting the insulators on connectors. Food for thought.
Florida , USA
The attached link is the soldering station I had purchased on Amazon. It is no longer available, but this will give you an idea of what I found to be a great soldering problem solver.
https://www.amazon.com/gp/product/B08DXHQXW8/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8&psc=1
XT60 CONNECTORS
Last year I bought a similar soldering iron with a temp. read out, excellent soldering iron. I wanted one like my son has and I had tried it and liked it. There were many for sale and so I found one on ebay that also included 'make me an offer'. So I took 10% off and that is what I got it for . I think about £28 used it ever since.
However for large items like soldering battery contacts I have a large 75 watt one which has a large mass soldering head.
I never throw away my duff Nicads, I put them to one side and when there are enough I take them apart and find the still working cells, test for discharge rate and then solder them together as a new battery.
XT60 CONNECTORS
Florida, USA 🇺🇸
XT60 CONNECTORS
XT60 CONNECTORS
I agree with most of the previous replies. I have made many such connections over the years and always use a good flux paste and NOT lead free solder as that requires too high a temperature. I flux and tin the connector and flux and tin or re-tin any leads that are already tinned to ensure any lead free solder is reduced (you can buy low melt solder to do the job but it costs). I use a temperature controlled iron set to 400+deg and hold the connector and wire with wooden clothes pegs ( or any similar mounting). Heat the wire and put with the iron to the connector until the solder flows ( you may need to add more solder) then remove the iron and leave to cool. As others have said finish off by cleaning (IPA) and push the heat shrink cover over the joint and seal.
The most important part in the process is the flux as this helps the solder flow quickly and as a result reduces the time required to apply the heat
Most batteries are supplied with the connector pre attached. Should it be of a different type to your requirements I would either make up your own conversion lead or buy an adapter. Soldering live wires connected to a battery (especially a LiPo or similar) is high risk and is best left to the experts.
XT60 CONNECTORS
1. Ensure all surfaces are chemically clean
2. Join the XT male and female connectors together
3. Pre-tin the wire end and the connector
4. Use a 100Amp soldering iron when making the final soldered connection.
Good luck
XT60 CONNECTORS
The key is to use a high powered soldering gun, minimum 100 watt, not the little 35-40watt pencil soldering units.
I always use a little solder flux in the connector socket and on the wire, then load up your soldering tip with solder, stick your wire into the wire socket then hit the joint with the solder.
XT60 CONNECTORS
XT60 CONNECTORS
XT60 CONNECTORS
That way the connector will not distort under heat and so make difficult or even impossible to connect once the job is done.
Additionally, the pre-joined connector will allow excess heat to safely disperse.
Good luck.
Dr John. F. Leeds and Bradford. BBC. 😊😊😊😊
XT60 CONNECTORS
I spent months doing really crap soldering then ran out of the cheap solder I was using, grabbed some I picked up when clearing out my late father-in-laws loft. Used his old solder and it changed they way I solder immediately. Not exactly life changing but the right solder has made a major difference.
I’m using RS multi core Savbit, made a huge difference from the cheap stuff I’ve always used, haven’t melted a connector since I started using it.
XT60 CONNECTORS
XT60 CONNECTORS
Gostado por
A carregar…
