Mobile Marine Models T12 Alternative
Iniciado por AtreiusModels
3 replies 11 gostos Última atividade: há 3 anos
Hi AtreiusModels
The T12 is I believe a 12v brushed high tork motor favoured by Tug modellers for its high pulling power. We really need to know what model you are going to install the motor in to and the size and pitch of the prop. There are many similar motors available and providing the details of the model will help making the best choice for your intended use.
Gostado por Len1 and Scratchbuilder and
Agree with RodC, also need to know the voltage
Gostado por RNinMunich
I suggest that you post the specs of the motor that you are looking to find an alternative for, for instance is it brushed or brushless? If brushed what is the case diameter and length? If brushless is it an inrunner or an OutRunner? And what is the KV?
VA3ROD
Hello fellow model mariners, I thought I'd posted this here before but could anyone advise on alternatives to the Mobile Marine Models T12 motor please? Thank you in advance 😊
I've contacted them and they're having issues getting them from the supplier and may be seeking to have them made elsewhere.
Gostado por dave976 and hermank and
