Huntsman refurb
Huntsman refurb
Pete.
Huntsman refurb
Shaun
Huntsman refurb
That's if I survive my ale trail in Hull this weekend 😁
Alan
Huntsman refurb
Windows tinted and fitted, windscreen fitted and finished off with car body trim and painted plasticard, bollards and cleats made, so, not much left now.
Huntsman refurb
You need a solder specifically for stainless.
Huntsman refurb
Looking good Ian
Alan
Huntsman refurb
I fitted the wooden handrails and made and fitted the pushpit and pullpit rails. These are made of 3mm stainless soft soldered together.
Ian
Huntsman refurb
what a great find!
Huntsman refurb
Alan, I ordered some of that trim yesterday afternoon, it arrived today and looks perfect for the job.
Well done that man!
Ian
Huntsman refurb
Huntsman refurb
The front seats are piped but not the aft bench seats yet.
Ian
Huntsman refurb
The seats will have white piping on them eventually, will they not? 😁
looks good Ian
Alan
Huntsman refurb
I think I may have solved the windscreen issue with a little help from another member, I have ordered some car body work trim that appears to be the right size, so, fingers crossed!
Ian
Huntsman refurb
Huntsman refurb
Alan
Huntsman refurb
Your B&Q must be better than ours, I couldnt find anything like you suggested. The nearest was white plastic edge trim which was far to big to go over 1mm lexan.
Ian (still mulling it over) 💭
Huntsman refurb
I used some black plastic trim from the local B & Q superstore, unfortunately I can describe it any better. it was for the top of the frame, its almost a "U" profile and just slipped snugly onto the lexan. I bent it by putting it in hot water. For the middle frames between the windows, it is just strips of plasticard, same at the bottom as its not functional just for show.
If you are painting it chrome, alloy etc, bend to shape and paint off the model so then you don't need to mask the lexan. I scrounged some window tint offcuts from a local car window tinting company and tinted the screen and side windows. if you zoom this pic you can almost see what I am rambling on about. I also fitted the screen with some small bolts, hidden behind the air scoops, so the screen can be removed if it ever gets damaged, or the boat gets a repaint, which it needs!
Paul
Huntsman refurb
I have cut out the windscreen from 1mm lexan and want to create a frame effect around it.
I have tried adhesive aluminium tape, which seems to be ok until I get to curves, at which point it just buckles and tears.
Does anyone have any suggestions I might try?
Ian
Huntsman refurb
I used a hot air stripper. Mine has 3 heat settings, I used the mid setting and kept the blower about 2ft away and heated gently.
Ian
Huntsman refurb
Fortunately, the ones that came with the boat (wreck) were useable for taking a casting from, which I did in plaster of paris. They came out just fine.
Next, had a look at some peg board for the surface plate. Once recovered from the shock of the price for a bit of mdf covered in holes, I went to a diy store and bought an offcut of mdf for 10p and set to with my drill.
Next, a box was built for the holy mdf to sit on, with a tube to tape the hoover to underneath, and a frame to support the plastic sheet was knocked up.
The first couple of attempts weren't so good, but I soon got the hang of it and am pleased with the results.
Ian
Huntsman refurb
The hull has now been painted and covered with 2 coats of satin varnish.
I have also made a card template for the windscreen and cut slots in the top deck to fix it into. Next, it will be making a screen from 1mm lexan and see if it fits!
Ian
Huntsman refurb
The first attempt was stainless, that destroyed a milling tip in the process, and I made a boo boo with it that resulted in the two webs coming out in different thicknesses.
The second attempt, in aluminium, I forgot to lock the vertical feed during a cut which resulted in a nice, but unwanted slope on what was supposed to be a flat surface.
Ian
Huntsman refurb
Alan
Huntsman refurb
Huntsman refurb
I have made and fitted window frames, a cabin door in the cockpit and some handrails (to be fitted).
I cut the handrails from some scrap mahogany, each one is two lengths of 2 mm glued together and cut using the milling machine, nice and easy that way.
Ian
Huntsman refurb
The hull has had two coats of z poxy, a rub down and two coats of primer.
Before putting the top coat on the hull I decided to do the deck planking first, which I have progressed quite well today.
Ian
Huntsman refurb
Huntsman refurb
Huntsman refurb
The way my Huntsman has been built, the whole superstructure lifts off the hull, leaving very easy access to all the hull space, and under the cabins if needed, so I don't think I will need to cut holes in the bulkheads for access.
What did you use for the surround on the screen?
Ian
Huntsman refurb
Huntsman refurb
nice planking!
I may have come along too late, its just a suggestion, I have a Huntsman 28 (Veron design). I changed the roof design to be permanent so avoiding any unsightly hatches (Not sure how the Huntsman 31 is supposed to be?) The front cabin is such a waste of space when all sealed up, I decided to make the door entrance a removable panel, out of plasticard, secured by small magnets. it has proved to be so valuable, as now I can enter the front cabin and have some electronics in there, receiver, light unit, and plenty of room for data logging etc etc. Might be an idea for you?
Paul
Gostado por
A carregar…
