New Boat
New Boat
New Boat
But I keep them for my vintage display at various vintage shows.
So, until I win the lottery, when I will buy a lake just to sail my vintage boats, then when I'm gone my grandson will own my collection.
New Boat
Not only for steering, but also controls the speed and reversing.
Don't have a suitable transmitter for it so don't know if it still works.
Engine is a 1.3cc Mills, which is a good runner after a complete rebuild, now part of my vintage motor display.
New Boat
They were used on small GB Naval pinnaces when warships carried them.
One of our club members has made a few of them and they work very well.
New Boat
In contrast, a better performing setup is the z-drive with a propeller that runs in one direction only (for efficiency). To reverse, the dive is rotated 180 degrees.
With the depth of the Mississippi River (U.S.) varying so much most of the towboats are limited to a draft of nine feet What most people don't realize is there are large propellers under the boat, so large that the upper edge almost reaches even with the surface of the water. However, that is contained (concealed) in a large concave area in the under side of the hull. You can see that in the attached drawing is part of a complete set of plans I made with the intent of building the "M/V Arne Christiansen". (Shown with Graupner z-drives.)
New Boat
There is a full size company link at the end on towboats and Z drives.
Back when we had family holidays we all liked travel on the local canals. My wife also worked for Inland Waterways Ltd and we got a 50% discount but that was later.
Our first outing was in more of a scow design than traditional narrow boat and this had a Morris Minor 800cc engine converted to run on gas. This was a Z drive, the engine stayed still and the prop also moved around like a rudder.
Narrow boats frequently have a removeable tiller arm, like bent scaffolding tube, and the connection to the rudder or Z drive looks like a Z as well. So with the tiller removed you had no purchase on the rudder stock to move it.
Of course you took it in when you locked up for the night. On our gas boat you had to lift up a part of the deck to turn on the gas bottles for the engine just in front of where you steer from.
Our instructions were not to bring out the tiller and put it down and then lift the panel up as the tiller would slide overboard into the canal.
We had 2 boats out, my brother in law on the other. He was very senior in the GPO at the time so never listened to instructions, they were for other people. But we did get on well.
The obvious happened and he marched off to a telephone to get help! Me being a'lets see what we can do' type asked the next boat that came by if they could help and the lady produced the largest magnet I have seen on a rope!
Just one plunge of the magnet captured the tiller, I thanked the lady and we started up caught up with marching brother in law picked him up and got on with the holiday.
All on the boat had a job our son was navigator and had planned the route I was captain and cook! My wife was assistant navigator. I would ask son where we were and he would say. My wife would then say "How do you know"?
At the end of the holiday we broke it to her that all the bridges have numbers on! Our youngest who was about 5 then wanted to also have a job and she became the ship's cat.
https://www.thrustmaster.net/wp-content/uploads/2013/12/Z-Drives-for-Inland-Towboats-Brochure-2016-page-compressed.pdf
New Boat
You are correct but I was referring to the option where they are mounted below the hull, as per the pictures.
There are two types of Kort Nozzles, accelerating and decelerating. Both, as you pointed out, have an aerofoil cross section, the first the curvature is in the inside to accelerate the water flow and the second it is on the outside. The other fact is that the propellers should be designed for Kort Nozzles. The other point of interest is that there are two main types from a steering aspect, fixed with a conventional rudder and moving with one or more rudders attached to the nozzle.
New Boat
Re: Voith Schneider. "As draught, they are no deeper than Kort Nozzles or Azimuth Drives."
Not completely true being that many Korts and Z-drives are not mounted completely below the hull. In fact I believe that most Kort nozzles are in line with the propeller shafts. There are many real boats out there with the Z-drives no lower than the keel.
First, lets step back a bit. Kort nozzles are the shroud or "ring" around the propeller to direct more thrust along the axis of the shaft and reduce or eliminate the radial thrust caused by the design of the bare propeller. The Kort nozzle can be used with the propeller on a fixed shaft as well as on a Z-drive.
The "shroud" or frame around the VS drive is used to protect the vertical blades from the bottom. For applications in models it seems that the vertical blades would be more prone to weed clogging due to the open sides. Not all VS drives have this shroud.
Having a model boat with a VS drive certainly would attract attention when out of the water. In the water, boats with Z-drives and those with Kort nozzles and flanking rudders come somewhat close as to visual performance, i.e. "dancing around in a circle".
Lately, I have been making my own propellers and Korts. Note that Korts are not a simple ring like a cut off piece of pipe. They typically have a cross-section that looks more like an aircraft wing profile.
New Boat
Incidently the towboats on the Mississippi had big kort nozzles and sometimes 5000 HP of power. They used to fit close fitting props but as there were so many logs in the water they would jam up. The solution was to go back to round blade props and the engines just chewed up the logs without jamming up.
New Boat
I took a plastic medicine bottle of appropriate size and cut it to create a tapered tube. a gently drilled hole secures a piece of 1/8" brass rod so it easily connects to a rudder servo for steering. Then I made two slits to attach the plastic fins. I figured I it it didn't work out I could just replace it with a regular rudder. It actually works really well, better than I thought. It kinda looks O.K. too
New Boat
Vegetation could cause problems but there is normally a partial shroud around the vanes. As draught, they are no deeper than Korts Nozzels or Azimuth Drives. The only thing putting me off is the price. 40 years ago I often went out on the harbour tugs in Cape Town in South Africa and all of them had twin Voith Schneider drives, their ability to maneuver was exceptional.
New Boat
Any feedback from someone that has one?
Florida ⛱️, USA
New Boat
Roy, Great explanation of the drive types
New Boat
After some thought decided to make a new boat out of the starter. The pictures you now see are the finale result.
I liked the basic look of the hull but it was out of line. The first start was to brake the transom and reset it in line. Cleaned off the decking and built the sides. The pilot house and superstructure were remade in styrene .
The final result turned out very well.
Rick
New Boat
Azimuth drive is an underwater pod that also turns like a rudder but the motor is contained in the pod.
On the many large cruise ships that are around they may also have a fixed pod drive at the bow and 2 azimuth drives at the stern. The pods are used prop first in direction.
No rudders are used in both of these type of drives.
One of the benefits for the cruise ships is that the big diesels can be arranged around the hull to distribute the weight and also a diesel can be serviced at sea as it is probably one of four or more supplying the power needs.
The diesels all drive alternators that produce eventually a DC current. This goes to a central control and for the engines it is turned into a variable frequency AC which drives the engines which are very similar to brushless motors. It will also supply standard mains AC at 50 htz.
When a cruise ship is in a hot/warm climate the air conditioning may well be as much or perhaps more than the power needed for the engines.
If you check the performance of a cruise ship you will see that in the main cruising speed is about 18 knots, top speed is about 22 knots. Length of ship comes into play as well.
Do not confuse purpose built cruise ships with North Atlantic Liners. I think QM 2 is the last of these and they can maintain 30+ knots and are strengthened at the bow to stand the rough weather in the Atlantic.
A further point is that the quoted tonnage is not the displacement of the ships it is just the Gross Tonnage measured as 1 tonne per cubic meter of usable (what can be sold) space so e.g. the engine room is not included.
So whatever the latest largest cruise ship is and quoted as say 140,000 tons the displacement is a lot less!
Where-as for Naval aircraft carriers it is a displacement measurement.
Well there you are, feel free to pick me up on any errors!
Hope this answers your question. If you want absolute information then Richard Simpson who writes for Model Boats magazine is your man. I wrote an article on the workings of the Queen Victoria at launch and Richard checked it over for me before publishing.
New Boat
The very regular port holes suggest a kit when compared with the assembly, they have been neatly cut.
I suspect it has been the project of an older person feeling a bit bored and perhaps running out of time.....
On balance I would finish her, all of the dodgy work will be covered up anyway and in bright colours and some extra detail in the bridge area she could be transformed.
You say you have Schottel drives with the boat does that include motors? If powerful that might suggest what was needed for the model.
Good luck with the project.
New Boat
It’s your investment and obviously you saw something worthwhile in the model or you wouldn’t have bought it.
The flat bottom for a tug bothers me though with your experience and some imagination you could create a sole plate, add frames, cover them and come away with a different model than you bought.
Check out some tugs on www.towingline.com
You will find tugs of various sizes and shapes.
Have fun!
New Boat
○ The deck's camber is too extreme.
○ The alignment of everything is poor.
○ The rise in the steps is not in scale with the pilot house's door height.
○ Filler on the hull at this stage of construction - not yet.
○ Lack of bulwark.
----- and more.
I would toss it - not worth the time.
However, I am glad you posted this. Great to see everyone's input when responding to unknown model boats. Thanks!
Florida ⛱️, USA
Added 16 Nov 23: At a closer look on my large screen PC I noticed there are a lot of pencil markings for cutting wood pieces which seems to indicate it was not a kit which usually has printed or laser cut edges. Crooked hatches on the sides, again with pencil lines. Might want to look closer at the alignment of the six port holes on the front of the structure. Notice the centerline? Not my cup of tea. Lew
New Boat
The photos here indicate a flat bottom, is that true? What does the stern look like below? Could it take twin korts?
New Boat
New Boat
https://www.fairplay-towage.group/de/flotte/
New Boat
The length is 28"
The width is 12"
Hight at bow is 6.5"
Hight at stern is 4.5"
Any help appreciated🤞
Rick
Gostado por
A carregar…
