at a loss of cad or even the size measurements
Iniciado por Stephen T
13 replies 12 gostos Última atividade: há 3 anos
Gee, and I don't have any smokers in my model boats!
Florida ⛱️, USA
Gostado por Nickthesteam
Hey Lew, I have a smoker out in the back yard/garden ( yard to me garden to the missus)!
Nickthesteam... you cook as well as build model boats? Me too!
TerryH... if will be using a 3D printer you will most likely need a computer, laptop or desktop. Depending on what you are doing will drive how powerful it will need to be.
Will you be creating your own model or just downloading and printing pre-made models?
The Ender Neo probably comes with the slicer software (to load on a computer) which creates the GCODE files.
Florida ⛱️, USA
Gostado por Scratchbuilder and Nickthesteam
You boys are gonna have to give me lessons on 3d printing as just got an ender neo for Christmas and not a clue if I need a laptop or not
I must confess I didn't look too closely at the stl I found as I was in the middle of cooking dinner at the time...
Gostado por hermank
3D files, usually .STL and .OBJ, are resized or scaled up/down before they are sent to printer which typically uses .GCODE (or "go codes) to translate the 3D file to print the item. Kind of like putting a piece of paper on a copy machine and use reduce or enlarge.
Slicer (configured for a specific printer) software is often used to convert the 3D file to a GCODE file.
One can find "viewers" to look at the 3D file or even free 3D file editor such as Meshmixer to edit files. (Microsoft has "3D Viewer" in 10 but not 11. Free download on Microsoft. )
(Note that the GCODE file mentioned above is not a 3D file, but a directions file like used in NC machining.)
I hope this simple explanation shows the usual process of how 3D files are often printed and avoids misinformation on who to seek out to do this.
Florida ⛱️, USA
Also, you can check out the flow process I created about Shapeways.
https://lewsmodelboats.org/3D-models/ShapewaysProcess.png
Gostado por hermank and jumpugly
Printing guns or trying to find the right one for the job is definitely a head scratcher
Gostado por jumpugly
Nickthesteam - that is a pretty primitive model (free) on Thingiverse I doubt it would look good in 1/24 scale. However there are other sites some better ones (i.e., CGtrader). There is another one on Thingiverse (see link) that looks better but was created for wargaming. Not sure how that one would look enlarged.
Stephen T - As for dimensions you might be able to get them from the linked PDF. There are plenty of other drawings of that gun out there.
Florida 🌤️😉, USA
https://www.thingiverse.com/thing:4223200
https://www.ibiblio.org/hyperwar/USA/ref/TM/PDFs/TME9-369A_Germ88.pdf
Gostado por GaryLC and TerryH and
If you've got a 3d printer then Yeggi have the files for one
I’ll bet you can find one fir a 3D printer. Also places that have the 3D in a file of the gun can also print it
I have used cult for ship parts like doors. Other companies I buy or build from software my ship parts. Usually the software to print you can scale up or down to meet needs. Check out a machine I have is flash forge and use thier app to print with pic shows 1:96 guns n rocket launcher. Doors an more in the pic all 3D printed
Howard hager
why is is it this world some things are impossible to find i need to make a 88 mm U Boat deck gun in 1/24th scale no one does such a thing i have a part built boat that i have played with got it to go up and mostly down now have in mind its gun its one of those projects that might get finnished I have 4 boats on the go but this one is being the most annoying with the lack of information on German boats in this country But with british boats you can get most of it
Stephen james tucker
Gostado por Doogle
