LEDs
Iniciado por PhilH
15 replies 58 gostos Última atividade: há 3 anos
LEDs
Right ColinH, exact words, I agree with you.
There are no problems with low voltages and low currents.
The important thing is not to improvise with circuits and devices that use mains voltage (230 volts).
Gostado por Len1 and hermank
LEDs
We all make mistakes, that's how we learn.
The man who never made a mistake never made anything.
Gostado por Len1 and Rookysailor and
LEDs
Hi guys and thanks for good wishes and help ,I got on to the place where I bought the leds, he was quick to reply he told me to check the end of the wires ,it seemed strange that some work and some did not well it seems that the problem is the ends of wires have what have what the seller calls a protective covering may still be on ,well I have them and he is right,I did not it a thought I have all kinds of bulbs and always striped on the ends,I feel a bit stupid .
All the time I have wasted and how frustrating it has trying to get them to work. Sorry but I just needed to tell someone.
Philuk👍
Gostado por Len1 and hermank and
LEDs
Thanks Peter not sorted yet but I think it may have a brain freeze on my part I made some metal light shades I think I may have shorted them out "What we call a schoolboy error" 🤣🤣 been busy on the hulls of two boats I am working on I will post some pictures tomorrow 👍 will be back at it having fun making rowlocks 😂😂 the name just makes me laugh. My wife says I am ascest 🤣🤣
The spelling is intentional that what she said🤣🤣🤣
Gostado por hermank and PeterL3 and
LEDs
Hi philh don't worry we are all learning hope your lighting problem is sorted I am still learning at 81 you will get their in the end peterl👍👍👍👍👍😀
Gostado por Colin H and Len1 and
LEDs
Hi Phil hope you got your lighting problem sorted never worry about asking we all have to learn i am 81 and still learning regards peter l👍👍👍👍👍👍
LEDs
Forvyears, I hated dealing with LEDs due to the liw voltage required, but I now stock and sell good 12volt LEDs in many colors.
Gostado por RodC and PeterL3 and
LEDs
check with the supplier of the LED's as to what voltage they require if they have not already supplied a resistor. Bear in mind that different colors of LED's need different voltage.
LEN1
Gostado por Colin H and hermank and
LEDs
Hi PhilH.
I can answer for what I wrote, not for what other modelers say.
IIf you read carefully the fourth message of the topic "Led bulb / lights" you will see that all the answers are there.
The LEDs can be powered directly at their nominal voltage.
It corresponds to the voltage drop that an LED causes when electric current passes through it.
This voltage is a factory data like the operating current. You cannot make electrical circuits with LEDs if you don't know these data.
If you are able to supply the right supply voltage direct to your LED there is no need for resistor in series with it.
Since not everyone has the ability to regulate the input voltage but simply has a battery, it may be necessary to insert a resistor in series with the LED.
You said that you bought a voltage regulator if I'm not mistaken, so you don't need a resistor as long as you supply the right stabilized direct supply voltage to the LED.
It is necessary to insert a resistor in series with the LED when the battery supplies a voltage higher than the nominal voltage of the LED.
In this case the resistor will cause a voltage drop so that the right voltage reaches the LED.
For example, if the forward supply voltage is 2 volts and you have a 9 volt battery you need to cause a voltage drop of 7 volts (9-2).
To cause the correct voltage drop you must insert the resistor with the correct ohmic resistance value.
How do you do?
It's all explained in that message with very simple mathematical operations that apply Ohm's first law.
There are also various examples with different types of batteries and with direct power supply to the LED at 2 and 3 volts.
I also explained what the advantages and disadvantages of connections in series and connections in parallel are, as well as attention to the powers involved.
For this reason, if you want me to help you, it is best to find that information and perhaps share it with images that make it clear how you connected the various components to each other.
Don't worry, these are solvable problems.
https://model-boats.com/forum/135645
Gostado por PeterL3 and Len1 and
LEDs
You will need a resistor in series with the LED. The size of the resistor will depend on the current rating of the LED. Just use Ohms Law to work out the size of the resistor. In my experience you certainly do not have to be exact with the resistance value but if you go too low th LED will eventually fail.
Bob
Gostado por RNinMunich and PeterL3 and
LEDs
Now that's funny I was told here that if you the same voltage you would not need resistors, so no resistor they are wired or will be wired to a voltage board set at 3 volts.
Philuk
Gostado por PeterL3 and Colin H
LEDs
Hi PhilH.
To help you I would need some information, because we have already written in the other topic what there was to say in general in terms of theory and practice.
Could you tell me what the voltage drop is (corresponds to the direct power supply to turn on the single LED).
I would also like to know if they already have their own integrated resistor and what their nominal operating current is. This information is provided by the seller and is essential for the correct use of the LEDs, so you should not have any difficulty finding them (since you have recently purchased them).
If I remember correctly you opted for the parallel connection.
Some photos would be very helpful.
LEDs
You did not mention the current limiting resistors. These are very important for the life of the LEDs.
But definitely good connections are a must for any circuit.
Good luck
LEDs
The only pre-requisite for LEDs is to ensure you have all + Positive wires together, and all
- negative wires together and of course, matching those wires to the +,- of the battery.
Gostado por Scamp and PeterL3 and
LEDs
Hi guys
I am sorry to bring this subject up again,
I a bag of led wired bulb I put three in mast, they where working fine now when I come to mount the mast they aren't working 😔 tried each set of wires to each bulb nothing,so got my adjustable voltage board ,was using batteries two 1.5 volt yes 3 volt LEDs nothing checked all permutations of wires in case I mixed them up nothing 😕,so I thought I will get new ones out of the bag nothing am I missing something I am getting paranoid 🤔who said that tried my main mast already finished all LEDs work of batteries and power board,
I'm going to test the rest of the bag of LEDs about six more .
The strange bit is last night I checked the mast and was working all I did was to solder ends of wires in mast together so I could mount mast in cabin trying to finish main cabin 👍
Phil uk
Gostado por PeterL3 and RogerA1 and
