Spektrum DX6i compatible surface Rx advice pls...
Iniciado por PirateJohn
7 replies 23 gostos Última atividade: há 2 anos
I don't think the original post relates to submarines or carbon fiber boats.
Isaac
Gostado por Len1 and PirateJohn
900MHz & 2.4 GHz don't work well if the antenna is immersed, for example, video feed from submarine camera, or 2.4 used for control.
And 2.4 in a carbonfibre glider fuselage is unreliable as the carbon fibre attentuates the rf signal intended for the receiver
VA3ROD
Gostado por AlessandroSPQR and Len1 and
All 6 of my large boats use Spektrum radios. No issue. No need for an external antenna.
Just clearing up a point. I have a dozen Spectrum and Orange receivers already. I was just concerned about 2.4Ghz and blocking due to water and in hull installation. Do you run additional aerial or are the Spektrum, Orange and Lemons just fine without this?
Gostado por AlessandroSPQR and Rookysailor and
Hi John, I use Spektrum equipment, and the receivers I find best are, Spektrum AR6100e and for a cheaper one, from HobbyKing the Orange R615X works fine.
Cheers Pete😊
Gostado por AlessandroSPQR and Commodore-H and
have you tried phoning CMB (Cornwall Model Boats) I find them really helpful
Red Budd
Hi,
Returning to modelling and I have a DX6i Tx and am seeking advice on suitable/best compatible Rx for use on surface (marine) models?
All input welcome (happy with clones as well as Spectrum kit)
Thanks in advance.
