Transverse stability of ships (difference between shape stability and weight stability)
Iniciado por AlessandroSPQR
22 replies 77 gostos Última atividade: há 2 anos
Ronald and Royce ... hae' ... we have a lot of raccoons for this capsize test ... sadly, most don't make it ...
Gostado por RodC and RNinMunich and
Re: 19
Sailing 1:1 is better.
Hi Ronald, Spot on! Looks good, the hull mega improves with a mast etc. Look forward to seeing her sail.
Gostado por Ronald
Like This Roy!
Just needs a couple sails.
Gostado por peterd and roycv and
Hi all something got lost in translation here! My fault as I expect being temporarily in Australia and being upside down to many of you has crept into my post!
Before I go to the water, that is I am at home and preparing yacht for the first contact with the wet stuff, I turn it upside down to see if all is secure!
Clearly the anecdote that followed confused the issue. When I am right side up and return to the real world things may look different.
However, until then I am on holiday with my son the view from his patio is attached and we should be going full size sailing tomorrow, (whenever your tomorrow is)!
Pictures , me pre-covid about to sail under Sydney Harbour Bridge. I am sitting on the middle chair looking out across the inlet called Broken Water leading to Brisbane Water.
Nearly 4 more weeks of it then back home to winter or maybe early spring.
Gostado por DWBrinkman and Ronald and
I don't think it's even necessary to flip it underwater. It seems a bit exaggerated to me.
The wind can bend the ship to a certain point then it loses power on the sails because it blows away if they are very inclined.
Only giant waves would make it flip but I don't think you'll sail your models in the open sea in a storm.
Now that I think about it, an Italian modeler sailed his model on the sea (not in a storm though) from Sardinia to Liguria, a real feat. There's also the video.
Gostado por Peejay and DuncanP
You are not putting your model in the water upside down but this is a dry land test to confirm that inner components and deck components are secure, correct?
Your original post where you were being certified and physically in the water, I thought you decided to use that method with your models.
I thought it rather radical! Good thing I didn’t do it. But you are holding it upside down 🙃 to confirm everything stays put? Well, the servos are screwed down, the receiver is secured with velcro as is the battery pack. Hatches are pinned.
I would be surprised if anything moved out on the waves.
Gostado por Peejay
I hold the yacht often standing on a chair upside down. No one else involved, it is a matter of honour that nothing goes clataty bonk inside!
Gostado por Peejay and RossM and
Hi Ron, I agree with you.
You wrote: ". I don't like sailing my sailboats where the rail is submerged."
I also don't like this condition, I think many don't like it.
If water gets on the deck, it can enter the hold and then the stability and flotation of the model are unsafe.
However, it is better to prepare a naval model for the worst but avoid adverse weather conditions.
Gostado por Peejay and peterd
Royce
Are you saying you do an upside down test on your model yachts? Do you have a trained critter to swim out and haul on the halyards while it stands on the daggerboard?
Gostado por RPLedm and Peejay and
This is just for model yachts! Before I take out a newly completed model I do the upside down test.
This has the battery and all insides ready to be switched on. Turn the yacht upside down and see what happens. If all secure, including hatches as mine always lock down, then down to the water.
When I did a dinghy sailing course in a Wayfarer, we had to do capsize drill, and it was April and not very warm in the Solent!
Boat was capsized we were in the water with life jackets and then someone would stand on the exposed keel and grab the shrouds, usually me, and lean back until the boat was upright. Haul the the others on board and then we had a bailer to evacuate the water from the boat and sail back to base.
This was the last test for the basic RYA exam. I did do the advance one and also competent crew in a 36 foot yacht.
Lesson was to have everything secure so nothing floated off!
I am not sure what my angle was in this test? I am going to try and find out. I don’t like sailing my sailboats where the rail is submerged. Some will but it makes me nervous.
To me the second photo looks right.
Gostado por Peejay and DuncanP and
Allesandro,
Excellant!
I would like to point out another factor that applies especially to sailing vessels. If the heel is induced by wind, then that wind should be scaled to match the model. I am not familiar with the actual numbers involved, I am sure the David Taylor Model Basin in Maryland could tell you, but I am constantly reminding myself that my models operate in a 1:1 world, while they are 1/48 scale. Every 1" wave equates to a 4 foot sea!
This is even more relevant to sailing vessels. Unfortunately, those models NEED a non scale wind to operate relatively well.
Please keep your excellent comments coming!😀😀😀😀
Gostado por RodC and JockScott and
Hi RossM, regarding your question I read Toradog and Roycv's answer (even though the latter wrote in another topic, Ron's: "Making an Emma Jr.").
Roy's suggestion is very very interesting, I really appreciated it.
You know that I don't disdain calculations (at least those I can do) and I like to know the theory (as far as I can get), yet this time I completely support Toradog who wrote: "If I lean my model over to say 60 degrees and let go and it returns to upright... it is stable. If it does not and goes the other way(the all the way over), I need waders".
Let me explain my point: Roy was very good and gave you at least a starting point, very valuable. However, I would skip the wind part directly.
Start from this: whether it is the wind or a demiurge or an unknown force, whatever it is makes you tilt (transversely) the ship.
If this happens, is the model able to return to position, will it do so suddenly or very slowly? You need to work on this.
Toradog says 60 degrees (which in real ships would be an excellent result), I say tilt it to 90 degrees or almost. Make the mast almost touch the surface of the water (after having closed the deck well and waterproofed everything perfectly).
If it returns quickly to position then you can rest assured in my opinion.
As I was saying for a naval model you can obtain weight stability (or get very close to it) that is, obtain that the G: Center of gravity is below the B or CB: Center of Buoyancy.
With a bulbous fin you can do it relatively easily.
I did this test (I don't know if you remember it), I'll put the link at the end of the text.
I repeat, Roy has given you an excellent starting point on which to do your tests.
As I already told you (but you know better than me): By lengthening the fin you can decrease the weight at the end of it or the total weight of the fin.
If you want a low draft you have to increase the weight of the bulb within certain limits (you must not exceed the pre-established buoyancy line).
Sorry if I repeated myself.
I feel like giving you two pieces of advice even if you don't need them because you know things better than me.
Do the righting test with wet sails and complete setup (batteries, electronics, anchor etc. etc.)
When you finally decide on the ideal length of the fin and weight of the bulb for you, always leave a certain margin, do not reach the waterline. Half a centimeter or a centimeter. A greater freeboard is always useful. Or it could come in handy.
Speaking of these videos, in the first one I did not bring the mast up to the surface of the water because the hull was not closed.
In the second video I didn't bring the mast to the surface of the water because the hull wasn't well waterproofed yet and because the edge of the bathtub prevented me from doing so.
It was an intermediate test because the model wasn't finished yet and the sails were dry.
Hi JockScott, thanks also for your contribution of experience. I love to listen or read first-hand accounts, from those who have seen and experienced firsthand.
Gostado por hermank
Toradog,
I have SKENES ELEMENTS OF YACHT DESIGN, and I'm trying to wade through it
Gostado por RPLedm and AlessandroSPQR and
In my time in commercial shipping I often witnessed cargo officers after finishing loading operation would hoist using ships gear a piece of equipment (forklift/bulldozer etc) sitting on the pier and thus calculate the ship's stability at how quickly the vessel would right itself. He then would call the vessel either tender (higher point of Meta center) or stiff (lower point of M...)
Nope... I have a copy of "Fundamentals of Construction And Stability of Naval Ships" 1963.
It make for great reading in my "reading room", but, of course, most of the math is Star Trek years beyond me. I still get the gist of it though. 🤣
What I have learned: If I lean my model over to say 60 degrees and let go and it returns to upright... it is stable. If it does not and goes the other way(the all the way over), I need waders.🤣🤣🤣🤣🤣
Gostado por DuncanP and AlessandroSPQR and
Is this where we will come to learn how to keep a boat upright? Is this the place I come to to find my muse? I've taken a long break. Alessandro, give me a push. I must get back into this next step of designing and measuring the stability
Hi Toradog, thank you for your intervention and your invaluable contribution of experience, I really appreciate it very much.
You're absolutely right.
I hope for more contributions like yours on this topic.
I also imagine the effort of naval engineers who have to ensure the stability of modern warships such as frigates, when they have to place naval guns. For a certain period (after the Second World War) someone hypothesized the possibility of completely giving up cannons in favor of missiles. They immediately retraced their steps, considering the cannon still an irreplaceable weapon (despite the presence of more sophisticated systems).
Of course today they do not exceed a certain caliber ( I don't think more than 127 mm ) and are multi-role and much more compact but certainly still very heavy.
Sorry for the digression.
Thank you very much for your appreciation.
Gostado por hermank
Excellant Allesandro!"
Many modelers do not know that in real ships, not only is this condition not present but the metacentric height is not excessively high so as not to create a righting moment that is too abrupt (which would create problems for the crew and passengers, for example seasickness); in Italian we would say that we would have a ship that is "too hard". So a compromise is sought even at the expense of greater transverse stability.
I would also add that in real ships, the metacentric height changes, especially in warships through the depletion of fuel, water, ammunition, food ect. Furthermore damage to a ship also causes, at times, extreme change in MH that can lead to the loss of the ship.
I love your comments and analysis!😁😁😁
Gostado por hermank and AlessandroSPQR
Anyway Ross, the more I look at your splendid model the more I am convinced that you could have achieved good transverse stability even without a fin under the keel.
By replacing part of the keel with metal or heavy alloy you would have lowered the center of gravity sufficiently (enough to obtain a good righting thrust up to a good heel angle).
The Bluenoose has a very wide and deep keel.
Please note, this is not a suggestion but only a consideration, an observation (in a certain way perhaps a bet).
You are right to use the fin because it is the method you had in mind from the beginning, because it is a practical method, because it is a method that guarantees the result.
You actually have a very high and extensive sail surface, so it's better not to take risks.
Also at this point in the project you would have to create openings and breaks that are too risky for the structure of the Bluenoose, so continue with the idea of ​​the fin under the hull.
Gostado por hermank
Hi Ross, greetings to all modelers.
I took this topic from a discussion born on Ron's Build Blog (first link at the end of the text).
You did well to clarify the use of the correct term and the translation. Thank you.
I always have the doubt that the terms I use are incorrect and misleading, especially the technical ones.
I am addressing Ross, because I am answering a question of his but the discussion involves everyone, no one excluded.
Since we have invaded Ron's "build blog", I am reporting my last message here, otherwise the meaning of what I say cannot be understood.
"""""""""""""""""""""""""""""""""...However, in this regard I want to clarify something that many people are confused about. Let's say they don't have clear ideas.
In scale naval models we can more or less easily obtain a "weight stability" (in Italian manuals this term is used when the center of gravity is below the center of the hull).
In reality (with a few exceptions) almost all ships and boats (passenger ships, ferries, motorboats, oil tankers, ocean liners, cruisers, aircraft carriers, destroyers, frigates, corvettes, auxiliary ships, icebreakers, container ships, but also ancient galleons and vessels, as well as naos, caravels, carracks, triremes, liburmes, etc. etc.) only had "stability of form" (in Italian manuals this term is used when the center of gravity is above the center of the hull).
It follows that the righting thrust exists when the metacentric height is positive. In other words, the ship is able to right itself only within a certain angle of heel, not beyond.
Ships with "stability of form" beyond a certain angle will no longer be able to right themselves and will capsize.
Most ships, even in adverse weather conditions, do not suffer dangerous inclinations (except for a few cases in where tragedies occur)..."""""""""""""""""""""""""""""
and that was Ross's question [A useful question for everyone]:
"""""""""""""""""""You used the term
CENTRE OF THE HULL
Possibly lost in translation, does this refer to
CENTRE OF BUOYANCY OF THE HULL?
It is best ABOVE the centre of gravity.
CENTRE OF BUOYANCY will shift as the hull heels over.
Does centre of hull and centre of buoyancy refer to the same thing?"""""""""""""""""""""""""""""""""""""""
Yes Ross I was imprecise, I double-checked the terminology in English.
Fortunately the capital letters indicate the same terms in both English and Italian.
So, to avoid misunderstandings:
G: Center of gravity (in Italian "centro di gravità" or "baricentro" is the point where the weight force acts).
B or CB: Center of Buoyancy. ["The center through which the buoyant force acts. The CB moves as the underwater shape changes as the hull moves up and down (or rolls sideways) in the water. If the hull is floating free to trim or roll, the CB will always be directly under the center of gravity."]
M: Metacenter. ["the theoretical point around which the boat rolls or trims."]
GM: Metacentric height [It is the distance between the center of gravity of a ship and its metacentre. A larger metacentric height implies greater initial stability against overturning.]
So when I wrote "center of the hull" I meant B or CB (in Italian "centro di carena" or "centro di spinta di archimede".)
For the rest I confirm what I have already written, if something does not convince you just tell me. In this topic we can digress calmly.
In essence, I repeat, with very few exceptions, ships have a stability (which we in Italy call "stability of form" in my opinion in a very misleading way, but this is how it is written in all the manuals) in which G [Centre of gravity] is above B or CB [Centre of Buoyancy].
In this condition, common to almost all ships, (see image no. 1) the position of M [Metacenter] is important.
As long as the metacentric height is positive there will be a righting moment.
In our scale naval models (not having the real needs of a real ship) we can obtain a stability of weight (in which G [Centre of gravity] is below B or CB [Centre of Buoyancy]).
In this case the ship never capsizes, the righting thrust is always present with any angle of inclination (it will always return to the initial position).
If you are still not convinced, I will use your own manuals to translate the ones in Italian and illustrate the situation better.
If you want I can go into more detail and clarify the issue of transverse stability.
https://model-boats.com/forum/147178#147766
Gostado por Ronald and hermank and
