Saying hello
Iniciado por Wolac
21 replies 102 gostos Última atividade: há 1 ano
#22 1
Saying hello
Hi Glyn,
Having the superstructure fixed could be an advantage if you can lift the cabin top or make a working hatch to give you enough access to change a battery or anything else you may need to do.
As long as you are able to reach anything that you need to get to, your boat will be more watertight with a fixed superstructure.
I build all my boats with a fixed superstructure if I can .
Gostado por hermank
#21 1
Saying hello
Hi Glyn.
The superstructure should definitely NOT be glued into place, it's essential that it remains removable for access to the interior.
All I can suggest is that you try to separate it as best as possible without doing too much damage.
I would rather hope that SLEC could help you out here but you should expect that it would likely incur material and carriage costs and as a worst-case scenario you could use the original sheet as a template with new wood that you can source from SLEC.
Good luck 🤞.
Robbob.😀
Gostado por tonyb2 and Ronald and
#20 1
Saying hello
Hi love your boats, the finishes are superb.
May I ask you a question?
Am I right in thinking that superstructure assembly for the SLEC pilot boat should NOT be glued into place so it can be lifted out to allow easier access to the inside of the hull.
I am sure that I have made a major error and fixed mine in. before I begin the job of hacking it out and scratch building another (I have asked SLEC if they will supply me with a new sheet of ply with the items needed, as they are all on the same supplied sheet) but as yet have not received a reply.
I do have the original sheet from where all the items were removed from so can use that to obtain accurate pattern if I have to.
many thanks, Glyn.
Let's sail in calm waters
Gostado por hermank
#18 1
Saying hello
Hi Wolac, in response to your question about where to post photos.
If it's a finished project, I think the best section is "Boat Harbor."
If the project is in progress, the best section would be "Build Blog."
I made a mistake and posted the work in progress in the forum.
Gostado por ChrisF and Wolle and
#17 1
Saying hello
Wolac.
Here's a link to a video I made of my Pilot Boat:
All of the design and implementation of the electrics is detailed in my build blog.
Robbob.
Gostado por tonyb2 and thadlietz and
#16 1
Saying hello
I did a similar solution to that in my Flert Tender using a Cat5 cable
Gostado por hermank and Wolle
#15 1
Saying hello
Hi Wolac.
That ribbon cable connects the lighting circuits and radar motor to the electronic switches that operate them.
There is a video file in the media gallery on this site that demonstrates the working of these features. If I can find it I'll post a link.
Robbob.
Gostado por Jay and tonyb2 and
#14 1
Saying hello
Ribbon,
That looks fantastic. Thanks for putting me onto it. I’m intrigued as to the purpose of the 9 pin D plug!
#13 1
Saying hello
Hi Wolac.
Welcome to this site, you will make lots of friends and there's always help and advice to be found here.
I built the SLEC pilot boat a little while ago and thoroughly enjoyed it although I did my own version of the cabin as I felt that the kit version needed some improvement.
Here's my build blog:
https://model-boats.com/blogs/71877
Have fun with the kit, all the parts are accurately cut and it goes together very well.
Robbob.
Gostado por tonyb2 and peterd and
#12 1
Saying hello
Don't let Jump put you off Wolac.
It's just the splinters in his wooden leg that make him a bit fractious sometimes😁😂🤣
He's a teddy bear really😉
Gostado por hermank and jumpugly and
#11 1
Saying hello
Aye! You’ve come to the best damn place there be! Good and helpful souls, one and all!!!
Keep the pix and questions coming, you’ll find many a builder more than happy to jump aboard!!! Arrggh!!!
Gostado por hermank and AlessandroSPQR and
#10 1
Saying hello
Wow, what a fantastic response from you guys. Brilliant. I feel more confident now Tanks, I’ll will start this weekend with the build, and post some photos. ( No laughing plz )
Where do I post them?
Thanks to all.
#9 1
Saying hello
Welcome on board!
I think you’ll find your pilot boat project reasonably straight forward. If you get stuck I’m sure you’ll get plenty of advice. Good luck!
#8 1
Saying hello
A hearty Welcome Aboard Wolac👍
If you get stuck with your build JUST YELL🤔
Someone here will surely have danced round the same barbecue sometime and have the solution.😊
Don't forget the Build Blog, pics please! Maybe you have some tips and tricks that may help others.
Gostado por Len1 and jumpugly and
Saying hello
Welcome to the 'Club!
There certainly is a wealth of resources and experience here, free to tap into anything you need, take many photos of your progress, and post your work on here.
Saying hello
Hello Wolac
Welcome to our forum.
Would you introduce the boat, with pictures and such. That would be great.
And if you have any questions, just ask.
Saying hello
Wolac, welcome
Good choice on the model, the pilot was one of my first and still favourite boats. Working through the Slec range, huntsman, fireboat etc is almost a right of passage!
There are lot of talented modellers here so feel free to shout!
Gostado por jumpugly and Nickthesteam and
Saying hello
Hello,
Just to introduce myself. I’m new to the hobby but have built aircraft in the past.
I’ve just bought the SLEC Pilot boat kit so I’m sure I will get stuck somewhere and will need your help! Anyone built this kit.
Glad to be aboard.
Gostado por Rookysailor and robbob and
