Motors past and present
If this all fails you could try replacing the motor with one of a similar size.
This motor is a great example of something from the past and deserves another shot at life.
Pity I am too far away to give you a hand with this.
Looking from the back, the two vertical metal plates go into the motor housing. There is a horizontal metal magnet block between the two vertical plates. It is removable and can be seen just inside the cowling (2nd pic).
My best remberence is I got it in the early 1960's with an open hull speedboat.
Now it is just turn on everything, run until you have had enough fun, go slow, fast, stop, reverse, come slowly to shore all while not having to talk over a loud engine sound. Switch off the motor with no oily residue.
Yep, theses are the days!
I must have spent hours starting various glow-plug marine engines on my knees this way.
If a helper was available to put some weight on the hull during the starting procedure, it was a bonus, but most of the time is used my knees to grip the hull while spinning the flywheel over.
The most hours spent spinning flywheels was on my Merco 61 twin-plug Marine and OS40 Marine engines as they were the ones that I used the most.
A well run-in engine was easy to start once the correct carburettor adjustment was made to suite the fuel being used.
The most difficult engines to start were the marine diesels and my 5cc ED Viking was probably the most tricky to balance the compression setting for starting and increasing it as soon as the engine started running.
Glow plug engines were much easier to start, but the recoil starter on my various two stroke petrol engines were by far the easiest ic engines to start .
Ed
My OCEANIC was still fitted with old speed controllers. I removed them because they were power guzzlers and got hot, unfortunately I no longer have them.
But I made a youtube video beforehand.
As I mentioned in a previous post, I ran .049 in a Sterling Chris Craft Buccaneer, the Tee Dee .15 in the picture I ran in a Dumas Thriftaway Too. Both were tethered boats.
I then moved onto RC and used various motors most of which I still have but they all have carbs.
Ed
The Tee Dee range of Cox motors were the “top-end” of the engine range and gave the highest performance.
I remember looking at them in my local model shop (The Modellers Den) many times as a young lad and marvelling at their looks and wishing that I could afford to buy them all.
Unfortunately I never bought any of them, but very much enjoyed running my BabeBee in various models - and in a mount on top of an up-turned orange box whenever I had the chance - and some fuel left in the can.
Gostado por
A carregar…
