Sailing barge sails
Iniciado por RickS
8 replies 15 gostos Última atividade: há 12 meses
#9 1
Sailing barge sails
Rick
It appears that in this photo there is a ruler of sorts? Using it along with the fill size ruler, measure the following:
Foot
Head
Luff
Leach
Send a photo of this when done.
Ron
Gostado por RossM and hermank
#8 1
Sailing barge sails
OK it's not much but this is all that came with the hull. Regards
Gostado por hermank
#7 1
Sailing barge sails
Ok, that's reasonable. Post a sail plan and we can get going
Gostado por hermank
Sailing barge sails
She is 60cms by 17cms. Sorry I have not replied sooner but the Base Hospital is becoming my second home. Regards
Gostado por hermank
Sailing barge sails
Rick
Just so we are all on the same page, a KITTY SIZED THAMES SAILING BARGE, is 65 tons and carries 1,000 feet of sail. How big a vessel are you working on. . . 😮?
Gostado por hermank
Sailing barge sails
Hi Ricks, I also used cotton poplin, which is the most common fabric for elegant white shirts.
If you don't like white, no problem; you can dye it or give it an antique look.
Gostado por hermank
Sailing barge sails
Hi Rick
Do you have a sail ⛵plan for your vessel? There are a number of us here that can work you through it, like Ron says
Ross
Gostado por hermank and AlessandroSPQR
Sailing barge sails
Rick
Are you able to get cotton poplin or a bed sheet? Possibly some fabric dye to make sail a reddish brown ?
If so, then making your own sails is not too difficult, that is unless you’re wanting something that is truly scale with all those hoops and rope stitches that a real canvas sail would have on it along with grommets.
Just a thought
Gostado por philcaretaker and JockScott and
Sailing barge sails
Hi all. I need a set of sails for a Kitty sized Thames Sailing barge sails. Regards
