Motor Mounts
Iniciado por SouthportPat
4 replies 7 gostos Última atividade: há 12 meses
Motor Mounts
I generally 3D design and print my own motor mounts, servo mounts and most everything that goes inside the hull. The photos are my Graupner "Dusseldorf" fireboat under complete rebuild (if I can get back to it).
Even if you buy motor mounts you still need to fasten them to something. This method (3D work) is easier for me. Temporarily hold the motor(s) in place, take measurements, then make the mounts.
Motor Mounts
My engine mounts are bought from eBay Pat and have never had any supply problems, but with the Blackpool Show coming up this weekend you could probably pick some up when you are there?
Gostado por hermank
Motor Mounts
I 3D print my motor mounts or fabricate them from 1/8" Aluminium sheet but Cornwall Model boats should have them and you will definately be able find some at the Blackpool Model Show this coming weekend..
Gostado por AlessandroSPQR and hermank and
Motor Mounts
Hi There
Looking for three engine mounts to go in a model MTB (1/32) using Overlander T3536T/06 Brushless engines - what would you recommend please.
Also can you recommend a UK based supplier that has stock in and can offer next day delivers - fed up wth being pointed to China and having to wait weeks for delivery
Many thanks
Gostado por Nickthesteam
