thinking aloud
3d printing is great isn't it, 1 minute it's all good, so easy, then for what seems like no reason, things just don't work. It's so much trial and error getting to the sweet spot for your printer and the specific material but you'll get there. If its ONLY the PetG that's giving you issues, try a search for settings for PetG with your specific machine and see what works for other folk.
You'll be up and grinning in no time!
Epaisseur couche 0.025 voir 0.010 ( temps plus long mais meilleur aspect...)
Durée exposition 8
vitesse levage 65 mm/mn
distance de levage 5 mm
quelques réglages que j'utilise avec une K1C...et ça marche très bien....mais derrière il reste un véritable travail de finition en enduit...
Bon courage...
Guy
thinking aloud
I'm going around in circles
one step forward and three back .
I purchase a roll of PETG from what I have been told using it should be easy-peasy . Not So!
It just isn't giving results that are halfway okay .
So what is the problem ?
The PETG isn't bonding 100% I have the printer turned full up.
PLA + was working so much better the only problem loss of detail .
Conclusion :
Do some more PLA testing
Tweek the settings.
Try printing at a slightly larger sise.
I won't give up Col
Gostado por
A carregar…
