2 escs
Iniciado por Phil56
3 replies 0 gostos 0 seguidores Última atividade: há 12 anos
2 escs
Thanks for the info will look at mixers and have cut the wire in case I forget later
2 escs
OHHHHHHHHHHH before I forget if your intending to use BEC from one ESC please remember to disconnect the positive lead from the other ESC so you don't fry something
2 escs
yes you can BUT if you buy a mixer you can have differential speed control to each motor. Any number of companies make them
http://www.cornwallmodelboats.co.uk/acatalog/mtroniks_wtail.html
is one example that should solve all your problems.
2 escs
Can anyone help I am attempting a twin prop fire boat .I have 2 motors 2 viper secs and 2 nimh batteries .can I link the 2 secs with a y lead and operate them on a single channel
