Superglue, without question.
A few days ago I glued some white styrene to brass tube. I later had to remove it, and the styrene tore as I did so. I had to file the superglue to remove it from the brass.
Same question has recently been asked.
Look under Brass Fittings in the Forum section.
Regards.
I have made 4 cleats for my Perkasa. I made them In brass and basically the bottom of them Is a 22mm x 8mm rectangle. My Inclination Is to use 2 part epoxy but I am not sure If It will bond metal to the hull permanently.
Can anyone recommend a glue to hold the brass to the painted deck?
Thanks In advance.
Les
Thanks In advance.
Les
Apoio Model Boats Website com uma participação e desbloqueie sem anúncios, descarregamentos de imagens, passados puzzles e mais — a partir de apenas alguns pounds por mês.
