reversing switch
Iniciado por fryer1966
1 reply 0 gostos 0 seguidores Última atividade: há 17 anos
reversing switch
Hi. its quite easy. Just buy a pair of lightweight "push and hold, to make switches". Then glue them directly to a minI servo, spaced so that the servo arm is just touching each.
Then, servo operated one way pushes one switch to on and it operates the winch until you release when it automatically switches off. Connect the motor with polarity reversed to the other switch so that operating the servo the other way causes the winch to run in the opposite direction until released when it stops again
Cost of bits - about A£5-A£8 from EBay.
reversing switch
hI all
can anyone tell me If there Is a good reversing switch I can use on my dusseldorf boat which will operate the anchor motor and crane as the one that robbe uses Is difficult to obtain as well as expensive
thank you
fryer1966
