URLs /Email addresses
No more copying/pasting required!
Stephen
Put the cursor at the front of the address so the 'writing cursor' appears.
Press 'CNTRL+SHIFT and END together'.
The address should now be highlighted in sort of orange. Copy to address box in browser. CNTRL+C --> CNTRL+V
If necessary (too much or too little copied) adjust in browser.
It's a two finger trick. Put the cursor at the start of the URL, press Ctrl key and hold whilst moving the cursor to the end of the URL. Release the Ctrl key. Press and hold the Ctrl key and the C key. Release both.
Move the cursor to the address bar (I suggest you open a new page) and press and hold the CTRL key and the V key. Bingo you should have copied the URL. Hit enter and the web page should open. You can practice the copying and pasting anywhere so perhaps try it on the same page to see it working.
Hope this helps
It is best not to post personal emails on open forums. if you want to share your email its is safer to use a private message.
Use the same procedure to copy and paste into your email address bar
Gostado por
A carregar…
