arun 54
Iniciado por pipsteam66
11 replies 12 gostos 0 seguidores Última atividade: há 9 anos
arun 54
There certainly were 2 types of Arun,and these where very much different.Some where made of wood and the later ones of glass fibre composite.There were 52 footers and 54 footers.The sterns on some were very fifferent to others.Adrian Clutterbuck as already suggested is a good man to contact and by joining the Lifeboat Enthusiasts Society, you will gain a whole load of information.I think you will find that the superstructure supplied with most models,is for a 54 foot version.
Hope this helps
Mick F
Gostado por suntugs
arun 54
Thanks Dave, I,m amazed at the wealth of info that is available on this site, many thanks.. Regards Muddy..
Gostado por AlanRJU
arun 54
You can also check the RNLI library on line. They sell arrangement
drawings for their vessels
arun 54
Hi pipstream and muddy
The first two Aruns were 52' but the next 5 were 54' but the rounded transom proved to be un-seawothy so later versions were all 52'.
There is a very useful book RNLI Motor Lifeboats by Nicholas Leach that gives detail of the Aruns with pics as well as many more.
Gostado por AlanRJU and muddy
arun 54
Hello, Try Arun 52..As far as i can recall there were only the 52 Footers.. I may be wrong ! Or as someone has mentioned The Enthusiasts Society of the RNLI, they very helpfull. The Main Man used be a chap named Mr .... Clutterbuck..
Good hunting Muddy.
Gostado por AlanRJU
arun 54
Hi Phil
Join the Lifeboats Enthusiasts socy or visit their stand at most large model shows. They have an extensive collection of photos of all lifeboat types. There are different types of Arun so I suggest you Google to make sure you build the correct cabin for your hull.
There are also dedicated web sites for Lifeboats and Mayhem also have some good build blogs
Gostado por suntugs and battleshipbuff and
arun 54
hi,i have been in touch with greenwitch museum,they state they have no plans for the arun 54.photographs would be fine if anyone has any.cheers.phil
Gostado por suntugs
arun 54
Tug to rescue my other ships - yes 👍Lifeboat for the crew - 'ard luck 🤔
Good luck with the witches pipsteam 😉😉
arun 54
Sorry I couldn't be any more help, I'm busy with other models, I've not got my head around lifeboats yet👍
Gostado por suntugs
arun 54
hi,thank you very much for the quick response to my question,will get in touch with greenwitch museum,
Gostado por suntugs
arun 54
A quick 30 second look with my pal Google yielded:-
Greenwich maritime museum have the plans and sell copies of every RNLI boat
Enjoy!
Wayne
Gostado por suntugs
arun 54
hi,does anyone have or know where I can purchase a set of plans for the arun 54 lifeboat.i purchased the hul from models by design but they don't do the supersructure moulding.it is the 1/12 scale model.thank you.
