Motor Cooling
Iniciado por Oyster
2 replies 0 gostos 0 seguidores Última atividade: há 9 anos
Motor Cooling
SHG Models sell a water pump that can be run for long time, l have one on my TID, and l've run for over 3/4 of an hour. Hope this helps.
Regards Dave
Motor Cooling
Not an expert on this but I think the usual,(easiest) way is via a water pickup behind the prop and then exhausted though the side or whereever looks right. I have heard of motors or ESC's being fitted with temperature sensors that turn on a pump if the heat starts to build up. I think most pumps will only work for a short period at a time.
Motor Cooling
Just curious. When setting up cooling coils for a motor does it run off a pump or just sea to sea piping.
