Simprop Zaunkönig (Wren)
Iniciado por RNinMunich
0 replies 0 gostos 0 seguidores Última atividade: há 9 anos
Spin off from " Re Sea Rover by Wingcoax" !
This ain't a boat, so do I have to convert it to a float-plane to qualify for help here!!?? i know some of you guys are experienced fliers. 👍
After an exchange about batteries and glow plugs etc I dug my old Zaunkönig (Wren in English) out of the cellar and she was in a pretty sorry state Pic 1 🤔
Have now cleaned it up a bit (judicious use of Cillit Bang and a fine mesh scouring pad!) and she looks much more cheerful. Pics 2 and 3.
Original Wen Mac/Cox 0.49 long since removed (still kicking around somewhere) and I would like to electrify it. Any advice on motor, prop etc would be extremely welcome.
Purists will note that I have extended the top plane, from original 410mm to 615mm! This is an attempt to improve the glide characteristic and above all dampen the incredible roll rate! A gentle bank could suddenly turn into a twinkle roll so fast you couldn't count 🤔 Mod never tested due to move to Germany, new career, new lady, and the demise of many IC flying fields.
I have loads of mini and micro servos, pico RXs (yes Dave, some 35MHz!) so they aren't a problem. But what motor, prop, ESC, battery?
Have thought of Micron radio for a combi RX/ESC or a mini ESC with one of my pico RXs, but have no idea for motor and prop! Original prop is 15cm diameter. Pitch ??
Total weight of all the bits you can see here is 156gm.
Would be nice to get a bit of history into the air.
All contributions gratefully received 😉
Cheers Doug 😎
PS: she doesn't need to be a 'rocket' just tootling around would suit my flying skills!😉 PPS: plan in background is HMS ARK ROYAL (WW2) scale ~1:192.
