1/12 scale fittings
1/12 scale fittings
Which fittings do you require. I make quite a few fittings for my 1/12 scale lifeboats so may be able to help.
1/12 scale fittings
cheers matt
1/12 scale fittings
1/12 scale fittings
cheers Matt
1/12 scale fittings
I am also com pleating a Solent class L/Boat. Try macsmouldings.co.uk for items like lifebelts, access doors, radars and other sundry fittings. They are resin cast and have excellent detail.
Good Luck
Griff
1/12 scale fittings
Rather thin on the ground, especially for the Solent model. Model Slipway do some 1/12 scale fittings in white metal and speedline models have some super detail stanchions. The aerials were fairly basic dipoles so I made mine from brass tube and rod, soft soldered where required. I made most of the other fittings from dowel or brass rod/tube but I do have a lathe so turning to shape was possible. if you need to make several bits the same you could try using polyester resin in a silicon mould made from one master - may be useful for the doors / window frames.
Good luck
1/12 scale fittings
I have bought rail stanchons that are to small and fine rod to fit thats bent when delivred.a mast thats to small the list goes on.can I buy fittings of this size or do model shops give false Info just to make a sale. please If you can help I would like to hear from you.
thanks matt
Gostado por
A carregar…
