Matching motor to Propellor
Iniciado por CplScotty
1 reply 0 gostos 0 seguidores Última atividade: há 9 anos
HI Scotty, First of all, Shaft, the length is the critical bit, the roller bearing shafts are superb, so shaft Diameter, probably 4mm would suit your needs.
Coupling, the center is a U/J, with inserts of the correct size, 5mm plain for the motor, 4mm threaded for the shaft.
Prop. 60mm, Raboesch from Deans, 4mm thread.
Contact Deans, they will sort all the right bits you need into a package.
Etherow Model Boat Club
My motor has a 5mm shaft. I need to source a 60mm dia prop, then prop shaft and coupler.
I like the roller bearing type shafts at Deans Marine but I'm Getting confused as to shaft dia's and connecting to propellor, Help please!
