cooler
Iniciado por acrefour
2 replies 0 gostos 0 seguidores Última atividade: há 9 anos
cooler
Dave M is right, but, if you have the 46" hull at slow speeds you might find a lack of cooling, due to the long distance to the motor's, a pump will cure this, but, look for a low watt pump, 10 L PM will be fine. I like my outflow at the stern as the exhaust but it can be masked with the propwash
Etherow Model Boat Club
cooler
A correctly positioned scoop just aft of the propeller and a side exit pipe will work fine. Makes sure the exit is above the waterline but about level with the motor outlet pipe to avoid air locks.
cooler
Hi can someone help me having a R A F fire and rescue craft i have just put a water scoop in the hull to cool the motor would it be better to install a electric pump to circulate the water faster .👍
