New Smoke Generators
Iniciado por shane
1 reply 0 gostos Última atividade: há 7 anos
My SG 1 works well, and looks good, in my Clyde Puffer. However, only works on 14v--- not the 6 to 7v recommended
HI to all,
I hope everyone had a good Christmas...
I have started a new line of smoke generators here In Australia, At the moment I have 2 sizes available and more on the drawing board. These new units will run on 12 volts and draw about 1 amp using oil based fluid.
Two Sizes
SG-1 80 x 45 x 50mm outlet 1/2" This unit Is design for the smaller craft or small spaces a neat little unit that performs great runs for 25mins on 1 fill of the tank (25mls) $65.00
SG-2 100 x 65 x 60mm outlet 1/2" Designed for the larger boats with a bigger tank and more powerful fan unit runs for 40min on 1 fill of the tank (35mls) $75.00
Both smoke generators can be connected directly to your power supply or to your motor for control of the fan speed ( Just need to make sure your speed controller can handle the extra power) you can set It up for 1 stack or 2 with 1/2" copper pipe fittings from your local Hardware shop..
Kit Includes :
1 x Smoke generator
1 x Smoke fluid (100mls)
1 x wire (300mm)
1 x nuts & washers
Check out the short clip of the smoke generator SG-1 at youtube
or on my website www.modelboatsandfittings.com email: Removed, PM Only - Admin
Model boats & fittings
