miskin clamps
miskin clamps
miskin clamps
https://www.micromark.com/mini-hand-tools/clamps?page=3
Part SKU:60926. $20.95. They are on back order at present.
Neat idea using a fine screw attached to the red knob which pushes a plate to hold the plank.
If you can't wait then two bits of wood, one the same thickness as the plank, and a fine screw would do the same. if you drill a fine hole in the former a drawing pin would be just as good.
I like the bulldog clips with a paper clip(?) idea as there is no need to drill holes, brilliant!
miskin clamps
Miskin Models is no more 🤔 Defunkt in 2014.
http://www.modelboats.co.uk/forums/postings.asp?th=94125
Cheers Doug 😎
miskin clamps
Gostado por
A carregar…
