Help
Iniciado por Gerry1
6 replies 4 gostos 0 seguidores Última atividade: há 9 anos
Help
Evenin' Gerry. OK understood. So I assume you have no electrical equipment, experience or components available.
Correct?
For an 'electrics novice' I am inclined to recommend you start with standard brushed motors and NiMH batteries. Cheaper and easier to manage for a novice. in which case 3 x 380/385 motors with 3 x 25mm 3 blade screws would be a good start. Can send some info on a suitable dual+1 ESC and rudder mixer tomorrow, getting late here in Munich now 😲
Don't worry there's lots of clever (been there dun that) guys here who'll help you through 😉 More later when I've cogitated a little 😊
One final thought: don't finish planking/skinning the hull until the motor mounts and prop shaft hull breakthroughs are sorted out and trial fitted for alignment. Doing that on a completed sealed hull is a pain in the you know where🤔 cheers Doug 😎
Gostado por Colin H
Help
Yes it's an elco from plan scratch build I have built a few but only static, this is my first working and I have no knowledge about running gear
Help
Hi Gerry, welcome aboard 👍
Don't mind some of our crustier Fleet Admirals😉, they mean well and have a wealth of knowledge 😉 First some basics (and forgive me if I'm preaching to the converted but the query was a bit bald to say the least!)! -
1 What experience do you have with RC boats?
2 Brushed or brushless motors? Are you aware of the pros and cons?
3 Battery: are you thinking NiMH or LiPO? Are you equipped for LiPOs, i.e. appropriate charger?
3 I assume you mean the ELCO 80 foot Patrol Torpedo Boat (PTB)?
Which at 1:32 would give a model of around 30 inches. Please confirm or let us know what original type the model should represent.
4 Are you scratch building from a plan, or from a kit?
If a kit which one? Maker?
Sorry for all the questions, but it's like computers; nothing in = nothing out!🤔 Some general rules (I know, rules are made to be bent til' they break!😉)
If you go brushed motors there is a neat dual ESC + rudder mixer on the market where you can also connect a third separate ESC for the centre motor, to give that extra OOOMPH at Full Ahead 😊
If you go brushless the basic rule is props no larger than the diameter of the motor. And use an out runner, good torque and SHOVE! inrunners are mostly for the fly boys 😉
Guideline: last year I bought a 28" LoA model of an ELCO 80 footer PTB from another member. it's fitted with 2 x 28xx brushless motors and 30mm 3 blade screws and 2 x HobbyKing XC-10A ESCs. The builder who sold it to me said it is 'almost uncontrollable'!
Whatever you do have fun with it, but if in doubt ASK, before you dump money in the boating lake! 🤔
Good luck and best regards, Doug 😎
Gostado por figtree7nts and Colin H and
Help
we need to know what motors your intending to use first.
Help
Hi i am building a 1:32 pt boat with 3 motors, what props speed control and batteries would I need please. Thank you
