Brushless Programming Cards
Anyway I tried it on 2 cards I have got and they did not work, resorted to sticks and code tones to turn off the break function.
Boat ran well if a bit too powerful, may use 7.4v instead of 11.1v
Features:
200A Brushless ESC with 5V/5A SBEC
Water cooling.
Waterproof design(Need to use 704 silicone rubber by yourself).
This super simple boat series comes with a limited range of programming functions and are designed to be plug-n-play.
A perfect ESC for those looking for something simple to use and economic.
Specifications:
Cont current: 200A
Burst current: 230A
BEC model: Switch
BEC output: 5V/5A
Recommend battery: Li-ion/Lipoly 2-7S;Ni-MH/Ni-Cd 6-20NIMH
Cooling: Watercooled
ESC weight: 124g
ESC size: 92mm 40mm 22mm
Please note only cost £17 at the time , now £32 (4/2018) via Amazon
slowing your pace when riding through town
cheers, Peter
eg programmes wrong section.
I have a new 200A brushless ESC but the instructions only show programming via the transmitter stick in response to tones. which I am having trouble turning off the brake option.
I wondered if a programing card may work? I have two Hobbyking cards both with different options available, I just don't want to damage or mess up the configuration.
Many thanks
Gostado por
A carregar…
