New Member
Iniciado por Richard7
6 replies 7 gostos 0 seguidores Última atividade: há 9 anos
New Member
hi richard doug is correct about that joint below the end of the prop shaft, you really need to place some ply strengtheners to either side of the joint as this will be a high stress area and as it is at the moment it is a weak point.
ron
Gostado por RNinMunich
New Member
Looks pretty neat 👍
Are you going to reinforce the joint in the keel as well?
I have a selection of micro and pico RC gear so installing in the cutter 'Gina 2' shouldn't be a problem. Motor and battery might be 😲
Pic shows roughly what she should look like! Hope mine turns out a bit neater though.
Cheers Doug 😎
Gostado por kmbcsecretary
New Member
Hi Doug, that old Billing Boat kit that your going to refurbish is the larger kit of the Norden. Before I purchased the St Canute that was my second choice, but I think its a difficult boat to fit radio control etc., so I went with the St Canute. Over the last few days I have been making space for the M500 motor, I have attached some pictures of the final result, the motor top shaft alignment is pretty good. in hindsight I should have gone with the M400, but hey-ho its done now, what do you think? Cheers Richard
Gostado por RNinMunich and kmbcsecretary and
New Member
Hi Richard, Re fitting the M500 see my answer in 'Help Needed new Builder Billings St Canute'. Nice fleet, good work 👍
Your 'Norden' is very similar to the Billing Danish Fish Cutter on my renovation list! Cheers Doug 😎
New Member
Hello, please see attached photos of my fleet todate, the Billing Boats Norden is a static model, the other two are fitted with Radio control...
Gostado por MouldBuilder and figtree7nts
New Member
Not sure I can advise on your issue but it would be good to see your fleet and I'm sure someone will come up with some suggestions and welcome to the site
New Member
Hello everyone, I am a new member I joined last week, I did write a post about my current model, the Billing Boats St Canute. However I am not sure if I posted this correctly, basically I am having a problem with fitting a M500 to this kit, did anyone see this? I have 3 other boats that I have completed Billing Boats, The Norden, Boulogne Etaples and the Aero-Naut Diva. I started boat building when I retired in 2016.....I look forward to hearing from you chaps....Richard7
