hull trouble on vintage yacht
Seguidores (1)
Agree, that wouldn't be advisable at all🤔
Suitably flattened off with wet n dry and then primed there shouldn't be any problem!
At least I never had any.
Mind you, I personally prefer to use the Deluxe Ezekote (Ezecote?)
It has several advantages over epoxy:-
One part so no messy mixing
No rushing about if you put too much hardner in😮
Water based so no 'orrible pong and no rock hard brushes😆
just wash 'em out with warm water😉
Dries and can be sanded and primed in 20 - 30 minutes.
That's what I've done with the wooden hulls of my Sea Scout, fish cutter and PTB and it's worked a treat.
Mervyn Pollitt
South Africa☹️⚡.
Mervyn Pollitt
South Africa
Colin's dead right I'm afraid🤔
If you only seal the inside, to stop water entering the hull, water can still soak into the wood from the real problem outside. The wood will then start to rot!
On my fish cutter I used EzeKote (Deluxe Materials) with FG tissue on the inside.
The several coats of Ezekote on the outside.
I had previously found any leaks or weak (thin) spote in the hull by shining a bright light inside it. Good luck🤞
Gostado por
A carregar…
