Hints and Tips.
Iniciado por Martin555
173 replies 557 gostos Última atividade: há 6 anos
#174
Hints and Tips.
“Help protect your delicate bits”
To protect and stop vibration on those mechanical or electrical items I use as shown in the photographs below.
Easily obtainable from your local double glazing outlets they are normally placed on the outside of the glass units to stop them rubbing together in transit.
They are plyable and one side is tacky so they will adhere to your components without leaving any residue.
I also use them for Engine block mountings.
Certainly at my local store they are happy to give them away.
Take care and stay safe.
Regards Bill.
Edit.
They are very easy to cut with a good sharp model knife or scissors.
Gostado por Seaspray and Rowen and
#172
Hints and Tips.
Prefer the hands and knees fingertip search with high LED worklight. Besides would be killed if I pulled the net curtains down to use as a filter.
Geoff
Geoff L.
Gostado por Scratchbuilder and Martin555 and
#169
Hints and Tips.
"I’ve got Lino in my boat shed .."
A Boooaaat shed!?😮 Plutocrat!
Folks, Bill is actually quite versatile.
Apart from scratching together his super boats outa almost nuthink,
he also plays the linoleum!
WITH HIS FEET 😁😂🤣
OKOK ... I'll get my coat ... and join Robbob outside ... Again 😉
Gostado por Colin H and Scratchbuilder and
#168
Hints and Tips.
Good idea Martin.
I’ve got Lino in my boat shed .....remember that?
Re the hoover,can’t afford to let she who must be obeyed see me using one of them 😂😂😂😂..Only joking 😬🤐
Bill.
Gostado por jbkiwi and RNinMunich and
#167
Hints and Tips.
JB,
Your lucky Paper bag!----- no i better stop there.
Gostado por Scratchbuilder and jbkiwi and
#166
Hints and Tips.
Luxury,!! we didn't have laminate flooring, or a floor to put it on, we used to live in a paper bag 😁😂
Gostado por cormorant and Scratchbuilder and
#165
Hints and Tips.
And for those of us who can’t afford carpet, only cheap laminate flooring.........?
#164
Hints and Tips.
Just a quick little Tip.
When your workshop carpet monster decides to devour the little bit that just pinged out of your tweezers think about putting a bit of fine mesh/net curtain/fruit bag on to the end of your vacuum cleaner hose with an elastic band.
Then vacuum the floor and that little bit dose not disappear in to the vacuum bag never to be seen again.
Gostado por Rookysailor and mistyoptic and
#162
Hints and Tips.
Hi Guys,
Just came across this on Utube.
Might come in useful to replicate some Chrome fittings.
Gostado por jbkiwi and ropeburn123 and
#161
Hints and Tips.
You can actually buy a centre finder from most hobby shops the aircraft boys use them to putin hinges
Gostado por Martin555
#160
Hints and Tips.
i got this from my local tool station (screwfix ) in the uk known here as sanding drums cost £10.99 box has a gap underneath to collect dust all mounter in my tower drill i have 2 tops 1 for the two larger drums and 1 for the rest
Gostado por figtree7nts and Martin555 and
#159
Hints and Tips.
Can you tell me how you built this. Ie The sander part not the box.
#158
Hints and Tips.
Hi Jacko.
Very clever.
Great adaptation.
Bill
#156
Hints and Tips.
Hi Jacko,
That is a great idea.
Thank's for sharing.
Gostado por jacko
#155
Hints and Tips.
I need to sand some of the ribs on a boat i am building and not having the correct sander i built this as the sander was over £55
Gostado por RNinMunich and MouldBuilder and
#154
Hints and Tips.
" in environmental terms the aerosol propellant still ends up in the atmosphere, filter or not,"
That's why air brushes are best. Propellant is compressed air 😊 so all the filter has to worry about is the paint particles floating about👍
Using acrylics on a water base also eliminates any nasty solvents getting into the atmosphere.
Snag is finding just the colour you need in acrylic🤔 Although LifeColour are pretty good.
Happy 'emitting' Rob 🙊
Gostado por Martin555 and Joe727
#153
Hints and Tips.
"Hi Doug.
I might have expected that from you 😆"
Would hate to disappoint you Rob😔😁
#152
Hints and Tips.
"Over here they call those 'Vollkörper Kondome'"
I expect you look very fetching in yours Doug 😂.
Now there's a first for this site !!!
Gostado por cormorant and marky and
#151
Hints and Tips.
Hi Doug.
I might have expected that from you 😆, in environmental terms the aerosol propellant still ends up in the atmosphere, filter or not, the pong dissipates very quickly and is considerably less noxious than some of some of my own emissions 😉
Rob.
Gostado por Ianh and MouldBuilder and
#150
Hints and Tips.
" I have a full 'hazmat' suit for that 🤣"
Over here they call those 'Vollkörper Kondome'! Rob.
#149
Hints and Tips.
"No filter, the fan exhausts through the outlet vent in the workshop (garage) door to the outside world."
Tush tush Rob😠
So you're dumping all the 'pong' outside!
My booth has the entire back wall covered with a first stage filter.
Replaceable with the same fibre stuff you can buy in sheets for cooker hoods.
Behind that is the extractor fan with it's own carbon filter.
THEN the pipe goes out the window.
BTW: I use FFP2 masks which don't make me look like a mutated insect!😁
Gostado por Ianh and marky and
#148
Hints and Tips.
It's been said that I look so much better with the mask on, and no, I don't wear it to go shopping, I have a full 'hazmat' suit for that 🤣
Rob.
Gostado por MouldBuilder and Commodore-H and
#147
Hints and Tips.
Hi Rob,
Do you use the same mask when you go out shopping LOL!!
#146
Hints and Tips.
Great spray booth. You look really nice too.
#145
Hints and Tips.
Hi Mark.
No filter, the fan exhausts through the outlet vent in the workshop (garage) door to the outside world. I always wear a spray mask so what I'm breathing is filtered.👍😁 and there's an old shower curtain so that I can spray 'inside the box' with the curtain behind me to exclude any over-spray from the workshop.😎
Rob.
Gostado por marky and Rookysailor and
#144
Hints and Tips.
Nice booth Robbob does the expelair have a filter fitted?.
Cheers Mark 👍
#143
Hints and Tips.
That's a very nice spray booth Rob.
#142
Hints and Tips.
Hi Martin.
I made mine from a Lazy Susan ring with a ball race mechanism and an old circular chipboard table top, total cost including the square ply base of about £15. It's proved to be an invaluable accessory to the spray booth along with the ventilation fan 😁
Rob.
Gostado por MouldBuilder and marky and
#141
Hints and Tips.
Hi Robbob,
I use a cake decorating turntable that i got from a car boot sale for 25p.
Gostado por ads90 and MouldBuilder
#140
Hints and Tips.
I have adapted a 'Lazy Susan' for use in my spray booth, it makes spraying a hull so much easier. Mine is on a square base that I can just pull forward to allow me to rotate a large hull 180 degrees.
Rob.
Gostado por MouldBuilder and Martin555 and
#139
Hints and Tips.
I use the ironing board and a revolving platter intended for mounting a TV on.
The latter also being very useful in the spray booth - so I bought two.😉
All round access, adjustable height and a good excuse not to iron me shirts😁
Cheers All, Doug 😎
#138
Hints and Tips.
Hi martin same sort of idea I bought the revolving bearing for a lazy susan table attached it to a piece of thick ply hey presto 360 degree.s of access.
Gostado por RNinMunich and Martin555 and
#137
Hints and Tips.
Hi Guys,
It Me again with another little tip.
I use a small camera tripod with a turn table attached as a work bench.
Ideal for working with small bits and pieces and is fully adjustable.
You can even work on it standing up or sitting down.
Is i am working on this plastic submarine kit i find it extremely useful.
Gostado por jimdogge and cormorant and
#136
Hints and Tips.
Now that's worth knowing!
Thanks, for sharing Martin555!
Cheers, Ed
"Fair winds calm Seas"
73
#134
Hints and Tips.
Hi Guys,
I have just seen this on utube, i have not tried it yet.
If anybody dose try it then i would love to know if it works as good as it looks on the video.
Gostado por MouldBuilder and figtree7nts and
#133
Hints and Tips.
Same here Martin, wife got me a packet from a
£ shop, but only four in the packet, but they look a little larger than the one's Marky got.😊
Cheers, Pete
#132
Hints and Tips.
I am beginning to worry about this hobby now.
We have eyeshadow for weathering.
Finger nail blocks for sanding.
What's next ???
#131
Hints and Tips.
Martin ,their handy in that you don't need to splash out on reams of wet and dry if your only after a wee bit , and you can always buff up your nails if you feel inclined 😂
#130
Hints and Tips.
Hi Marky,
That was lucky my wife went shopping this morning and picked up a packet.
But i only got four in the pack!
Thanks again.
Martn555.
#129
Hints and Tips.
That's a good tip Marky, i have put in a request with the wife to see if she would get some.
#128
Hints and Tips.
there it is, right in front of me the hole time 😊
#127
Hints and Tips.
Handy for rubbing down,polishing small areas ,originally designed for finger nails four different grades of paper, file, buff,smooth and polish on a soft block , 5 blocks for £1 from a well known pound shop (where everything is £1).
Cheers Marky
Gostado por Martin555 and jbkiwi and
#126
Hints and Tips.
Love your Cervia Tug, looking very realistic on the water, and if you ever get a cold day in Oz make sure you get out there and get some photos taken, so as I can see the steam which is not a problem here in the U/K as every other day is cold. Regards, Gary.
#125
Hints and Tips.
Fine Detale Sander.
Hi guys another little tip.
If you have some old scalpel blades that are blunt and you normally replace them with new ones, how about gluing a small piece of fine sand paper or wet/dry paper on to them.
Then trim to the shape of the blade.
It then becomes a nice thin sander that will get into those little awkward places.(especially if the blade is a long pointed one)
Gostado por fact77 and philcaretaker and
