Can anyone help please?
Seguidores (3)
- mturpin013Bronze
Sounds like you may have had something else connected to the RX which put a short (or a heavy impulse load) across the BEC supply line! Was there any other obvious damage to any wiring? Doug
Regards Brian
The Mtronics guys seem a reasonable bunch so I hope they'll send you a replacement 🤞
Re: fuse, my measurements on the Sea Scout with the same rating motor you have and 3S LiPo never showed more than about 8Amps current at full chat so I have fitted a red 10A car blade fuse.
Clearly visible in the pics I've posted. My ESC is also rated 30A. But I wouldn't fit more than a 15A fuse at most with that motor. Some might go to 20A but while protecting the ESC Ok that may risk damage to the motor or wiring before it blows.
Was glad to see that the RX had survived OK 😉
Good luck with Mtronics👍 Cheers, Doug 😎
Regarding fuse in the battery feed I’m unable to identify the stall current of the motor. Current rating for speed controller is 30 amps, what fuse would you suggest?
Thank again
Cheers Brian
I will. It’s strange I havent had the problem before either. Yes I have tested the receiver on the rudder servo and all is well there fortunately
Regards Brian
Would be good to know what went wrong, to help others avoid the problem👍
I also have several Mtronics ESCs; Viper Marine versions.
Not had any problems ..... YET 😉
Cheers, Doug
PS A quick thought! Have you tested the RX with just a servo connected after the disaster?
You'll need a separate RX battery (4.8 to 6V) to do this of course.
Thanks again, if I get an answer I’ll let you know
Cheers Brian
First mistake 🤔
Rule is ALWAYS switch on the TX FIRST! ALWAYS switch off the RX first.
This prevents the servos and/or ESC going mad because they are not getting a stable control signal with the TX off.
It doesn't matter which way you connect the 3 wires to the motor; as long as you don't mix up the red motor wire with the red battery wire! 💥 But since you say the motor ran that can't be the problem. A mix up is highly unlikely anyway.
Why switching on the TX apparently caused the 'magic smoke' is puzzling🤔 UNLESS maybe the throttle stick was set to full chat and the motor overreved and the inrush (or start up) current overloaded the ESC. But I thought that the Hydra is internally protected against this.
Can only suggest that you call Mtronics, or first go back to the shop with the sad remains!!
Your setup is virtually identical with my Sea Scout setup, just different makes but same values.
I use the car blade type fuses, see attached pic of Sea Scout's 'engine room.
I solder the fuse holder to a little Veroboard switchboard, but you can also get in-line versions.
Sorry I can't pinpoint the problem further😌
Good luck🤞
Doug
I have successfully connected it all together and run it on several occasions for test purposes without a problem.
The battery connects with a Tamia connector which can’t be reversed and the motor has three colours cables, red, yellow, blue as does the speed controller.
I switched in the RX before the TX and the motor ran as it has previously, I quickly switched on the TX and whoosh! Lots of smoke from the speed controller.
I am sure I connected the mayor/speed controller cables correctly however when it all went wrong I very quickly disconnected the battery and the motor leads so didn’t see how they were connected. One of the pins in the Tamia connector to the battery disappeared as well, not sure if it melted or broke off when I pulled it apart.
If I had connected the motor cables incorrectly would that have caused this.
Also, what type of fuse do you suggest? Eg car type
Thanks again
Agree with above advice re fusing, standard practice!
Fuse rating should be significantly less than the stall current of the motor and / or the maximum current rating of the ESC.
Fit fuse between battery and ESC.
With brushless (3 wire) motors you could fit fuses in each lead between ESC and motor but not normally necessary with Mtronic ESCs. They have built in motor short protection anyway.
To help you further we need to know the following-
- Make and model of the receiver, the Hydra manual contains warnings about the pin connections of older receivers!!
- Make and model of the motor,
- Are you using the BEC from the speed controller for the RX or a separate RX battery pack,
- If so did you disconnect the red wire between ESC and RX,
- Are you sure you connected the power capacitor the right way round?
PS: If all else fails- "Need Help? Call our specialists on 01943 461482" Ask the 'Moronic guys 😁
I put a fuse in the positive wire and it has saved several controller when connecting the wires the wrong way round on the battery hope this is of some help
Gostado por
A carregar…
