Miss Katherine Tugboat seen in boatyard, Mahone Bay, N.S. Canada
Seguidores (5)
- Newby7Bronze
- RookysailorSilver
Martin looks like Ron has big blue on steroid's 😁
Cheers Marky👍
The complete trials video from Ron in Canada - via South Africa!
Test #1 🤞
It woiks😊
You have done a good job on her.
I do like your Test facility, much bigger than my Big Blue LOL!!
It would not open there however in the top left corner there is a blue arrow that gives the option to download.
Did this however phone is not able to play mpg4 files. Should work on my computer.
Yep know that,never have a problem with media files but defo can’t open this one.
Regards Bill👍
I am looking forward to seeing her sea trials.
I did the following. Left the prop assembly alone, but removed material from the rudder. It is secured top and bottom; did a test several times, filing spots where the rudder and prop touched, so it should be fine for sea trials.
Thanks to all who participated, some on line answering questions and others via personal emails.
From experience I have removed the tip of a prop altogether for a similar reason (look at outboards) and its still a very fast little boat without much noticeable cavitation . However in this case agree with you that the blades themselves might pose a problem . I would personally remove the tip completely - leaving a flat face on the boss.
Hope that helps
Ron: screw the prop on nice and tight using Loctite or similar for security.
Fit a thrust washer as JB says and a collet and thrust washer at the inboard end.
See attached pic of the collet fitting on my Sea Scout.
For extra 'wiggle room' you can take a little off the prop hub, but take it easy.
You don't want to expose the end of the shaft!😮
PS Somehow I managed to boob with the measurements and had to add some extra packing washers as shims!🤔 Oh well, at least it works😉
Can I shave off some of that bulb to give the rudder some clearance? As it is those prop blades will be fairly close too.
As you say very easy with Corel - also used the laser to cut larger letters/window frames etc from very thin "stick on" Rowmark (metallic type for frames)
Hi Doug, This is an easy way to print white lettering using that method, (using Windows 'Paint' and white decal paper). Being that you can't see white lettering on the screen this method allows you to see what you are doing. 'Paint' is a bit crude and unfortunately does not allow you to 'cant' or bend letters to go round a curved surface (such as the tugs' stern where you need a curved decal) It also can leave jagged edges when blown up, which need manually tidying with some of the other tools.
Re your problem with the navy blue, you could have scanned a good sample of the colour, copied it to paint, and used the 'colour picker' and 'fill' tools to do your background (a small colour adjustment might be needed using the 'edit colours' tool) I did that with the BD6 which is genuine 'Charger Orange' metalic (a la Dukes of Hazzard - and the original colour of the planes side flash,) which turned out pretty close.
I used Corel Draw years ago which was very good (you could grab a word and twist it or bend it round in circles. Unfortunately it does not work on windows 8.1. There are much better drawing programs around today which would be great for decal making (note to self, - get one!) By the way, use the transparent selector to move things without bringing the background with them, (when moving something from outside the drawing onto the drawing)
Or
http://www.pcbsupplies.com/dry-transfer-lettering-white-letters-by-letraset
Looking probable
Alternatively there is still some Letraset type lettering around - now produced by the Chinese of course - seen it quite recently at the local Stationers . So Stationery/Office Goods/Art shop might well have some. Quite a few versions , colour & sizes.
Also lettering for kiddies in stick on plastic from some toy shops - many varieties in that too.
Also seen some glossy stick on "metallic" lettering for decorative labels etc from the local Stationers/Art shop - easlly painted as they are card based.
Thinks! If you use white decal paper 'all you have to do'🙄 is match your print background colour to the hull colour!
That's what I couldn't manage with the royal blue hull of my Sea Scout 🤔
But with a black hull it should be a bit easier.
Let us know how you get on.🤞
Cheers and G'night from Munich, Doug 😎
Forgot to mention Ron 😌-
You will need to first paint a block of white on the hull where you want to apply the decal prepared as described in my previous post!
Uvverwise you'd end up wiv black on black! Oops 😁
There is possibly one way to get the white on hull colour - with luck!
And that is to use the decal paper and prepare your print file with 'white' letters and a background colour to match your hull colour.
With your black hull that should work.
With my Royal Blue hull I gave up trying to match the colour after about ten attempts😭 That's when I switched to yellow lettering 😉
Bon chance mon ami!🤞
Ciao, Doug 😎
"how do you get an inkjet of laser printer, to print White ink"
That is the perennial problem 🤔
I've struggled with that as well, and really there ain't no satisfactory solution.
The basic answer is 'You can't!'
One of the drawbacks of digital technology I'm afraid.
Printers are designed principally to put text and images onto white paper.
Thus printing white digitally means effectively printing nothing🤔
RGB code 255,255,255. Hex code #FFFFFF. I.e. Nuffink!
Even the advent of transparent OHP film etc didn't change that cos it was already ingrained in the basic printer drivers☹️
It's also a question of basic physics,
You can make white light by mixing all the other colours, or basically red, green and blue. RGB - sound familiar?
But dat don't woik with paint or printing I'm afraid😭
There ain't no combination of the basic printer colours of black, cyan, magenta and yellow (or any artist's colours) that makes white! Cos painting / printing is a filtering process as opposed to the mixing process with light.
Trying to cut an outline from a white decal sheet is most likely doomed to failure.
Hat off if you manage it! If you can do it you might as well use Martin's tape stencil cutting technique, probably have more luck.🤞
Eventually I admitted defeat and used very bright yellow instead.
Probably more visible on the pond anyway.😁
(That's my excuse and I'm stuck with it!😔)
Sorry😌
You can buy white decal sheet, then print an outline
of text, but you will still need to cut out what you need, there is no easy way to get print whit text or numbers.👎
Cheers, Pete
Saw your query, but thought I'd take a back seat and see what others suggested before sticking my ubiquitous oar in!🙄
"Anyone know how to create lettering ....." Yes thanks Ron 😁
Seriously though folks ( moi? grave? 😂🤣)
Martin's method is great for really large lettering, like the pennant number on the hull of my 1/72 H class destroyer. Like I did 50 years ago using 2" masking tape. BUT!
For what you want to do it depends on;
- excellent eyesight,
- very sharp and pointed scalpels,
- and probably 50 years experience of graphic arts and architect model building, pre 'everything computerised'. (I did technical drawing back then😁)
Yes it CAN be done that way (use non-stretchy tape😉) given above prerequisites!
Looking at your response I read from that that you have a PC with some kind of text or graphics programme installed. And a printer; either laser or ink jet.
Those are the prerequisites for my preferred method, especially for small scale models. Which most of mine are; 1/35 to 1/350.
Quite simple! 😊
Basically I use Word for Windows to create the text, in any colour and text style you want. If it ain't on your PC Google Text Fonts until you find it!
When you are happy with the text print it on a 'Decal sheet'. See pic.
So called Water transfer paper. Google it. I bought mine from a UK supplier found on Ebay.
I usually do several test prints on plain paper until I'm really happy with the text, size and format.
When the print is dry you apply it to the model just like the plastic kit we used to build (remember the Airfix / Aurora etc days of our childhood? Tempus fugit!😮🤔)
Blot it with a tissue and when really dry fix it with a blast of matt or gloss varnish as takes your fancy 👍
Hope this helps, and that you are suitably equipped,
PS "next find the right size font"
You only need to use a font that looks like the original.
In Word, or similar text / graphic Apps, you can alter the size to suit what you want to do. 👍
First, use the word processor, next find the right size font, then print it out. cover font with tape, next take a sharp razor knife and cut each letter out! Now, place on boat hull and cover unwanted areas to protect from over spray.
Fine on a flat surface, but not on the slanted stern plate that is also curved...
Any other ideas???
Then, the long awaited Spring Thaw 😃
Working on the wheelhouse sun shade.
for the outlay you have had, nor the fun!😁
Cheers, Pete
Gostado por
A carregar…
