Drawing the Miss Katherine
Seguidores (1)
You really are getting along with Miss Katherine - a very good job you are making of it as well - most impressed. Are you going to plate the hull ? If you have a local print shop who do Litho printing - (they usually throw the plates away after one use) - ideal for plating - and a dressmakers wheel used on the wrong side makes rivets if you need those at all. Weld seams should be easy enough scribed with a ball point pen or knitting needle from the wrong side. Cardboard also works but not nearly as well.
main site (new kit not listed here yet)
ttps://www.rcgroups.com/forums/showthread.php?3367513-45-st-Type-Utility-Tug
RC Groups blurb - with some photos
they seem to be quite pricey on most items .........
I see in the photos of the hull, plates were about 12” wide and welded. The plates are not curved as you would see with steamed wooden planks.
If you look at the Boats section on RC groups you will see the Ad/blurb - might be of interest as there are some large pictures and a few details, perhaps they might sell a set of plans separately - they make it in various scales it seems. Its round bilge and not multi chine however.
It will be fantastic to see this project go from photos to drawing to completed model.
I wish you luck, and hope to see a build log soon.
looks great - you are really doing a good job there, lines are hard enough on a single chine hull - let alone one like this. Found it helped when doing multi chine hulls to draw a round bilge frame first then split it into however many chines needed. Done a couple that way - don't know if that would help you at all - don't want to teach grandmother to suck eggs - as you say its hard work getting them right .
Would love a copy when you are finished - its a beautiful tug.
You are doing a good job of the drawings.
Keep up the good work.
Gostado por
A carregar…
