Flysky TH9X with OpenTX and AFHDS-2A
Iniciado por Escrich
4 replies 3 gostos 0 seguidores Última atividade: há 7 anos
Thanks for your answer, yes, I was binding the devices several times, and I agree with you, just changing the module everything should work, but the reality is that the new combination didn’t work, even testing a lot of different communications setups in the transmitter, may be the old operating system is able to handle that but not the open tx, but as far as I know somebody has this combination working
Trying to learn something, trying to help each others
Hola Escrich,
Re "but it’s from the time before the emitter I’m using appeared in the market"
That shouldn't matter now Escrich, as by installing the FS-RM003 TX module you have apparently upgraded your TX to an 'i10' with AFHDS-2A.
Since your IA10B RX also uses the AFHDS-2A protocol they should work together 😉
Have you tried binding them yet? Good luck!
Gostado por Escrich
Yes, for sure, but it’s from the time before the emitter I’m using appeared in the market, thanks a lot for your help
Dear all I have a couple of this transmitters and I was changed operating system to OpenTX, but when I changed the transmission module, to have 10 channels, I discovered that the protocol it’s not longer AFHDS, instead of it new modules and receivers have the protocol AFHDS2, any one of you have this emitter working with FS-IA10 module?
