Just saying hello
Iniciado por adimike0001
17 replies 24 gostos Última atividade: há 7 anos
Just saying hello
Just an idea. Made Flower class with RC and for battery and motor/electronics access I cut the deck at a convenient point and glued Balsa strip under the edge of new hole. Then drilled 3mm pockets in balsa for - Magnet Expert® 3mm dia x 1mm thick N42 Neodymium Magnet - 0.19kg Pull ( Pack of 50 ) - £3.99 from Amazon UK, glued in magnets and added tiny pieces of tin(from bean cans!) to base of removed deck. I also stuck some self amalgamating tape to edge of hole for extra seal. The magnets hold extremely well but a little slip can lift the deck edge enough to start disengaging each magnet from it's tin counterpart. Not sure if this is doable on your build, but on my Flower it withstood (totally non scale speed run!) full power on local boating lake with no leaks. Hope it gives a bit of an out for the issue.
Gostado por Scratchbuilder and Martin555
Just saying hello
Ok I will take on board any advice
Question though
If I attach to the deck how would you change the battery?
I get what you mean and why
Just can’t seem to workout how I would do it without sealing off the hatch if I do attach to the deck
Or do you mean cut coamings to where the edges are?
Just saying hello
I did think about it
But thought it would be too much of a speed boat lol
It guides along nicely
Maybe the next one I might try a twin
Just saying hello
"Part built "
So far so good Mike👍
Shame you didn't go for an original true twin screw set up though.
PS A word to the wise though!
I would detach those coamings from the hatch decks and glue them permanently to the main deck. Only then can they properly serve their purpose.
Namely; to prevent ingress of water to the interior!
Your choice, your risk!😉
Gostado por Martin555
Just saying hello
Hi Mike,
Welcome aboard!
You'll soon see we are all a happy group!
Thanks, for sharing pic's of your boats!
Cheers, Ed
"Fair winds calm Seas"
73
Gostado por Martin555 and RNinMunich
Just saying hello
"I am sure it’s a 5 minute walk to Queen’s Park
Street opposite co op? "
No idea Mike, I'm in Munich, not far from the Ostpark😉
Just saying hello
They look fantastic
I am a complete newbie really being a driving instructor it’s really awkward hours
I do the modelling to de stress
I have a purpose built soundproofed workshop to kit out when I get to my house
Gostado por RNinMunich and Martin555
Just saying hello
"It’s actually frames with ply sides "
Didn't doubt that for one minute Mike.
Very like my balsa built H Class destroyer HMS Hotspur.
She was scaled up to 1/72 from the Airfix 1/600 kit when I was about 15. A fiddly job!
If you need any help with the superstructure let me know.
I built mine twice!
First using 1/16 balsa, second (about 20 years later) using 0.5mm ply on 1/8 square obeche frames. Nowadays I might use plasticard😉 Crew was shanghaied from my Airfix 1/72 8th Army and Afrika Korps soldiers. Cap'n on the bridge is/was a Panzer Kommandant😉
I also glass fibred the original weak 1/32nd balsa hull and upgraded the original tiny Mabuchi motors to a pair of Graupner 540s and added full RC during that refit.
Just saying hello
It has all the working gear in
I will take some more photos later tonight
Got plenty of time
My house is all but packed so running out of things to do
Stay safe everyone
Hope to meet you guys around July time
Just got to work membership and I take it permission from local council?
Just saying hello
Way to go adi👍
Looking forward to the rest when you've got the move behind you.
That third pic looks like how my very first destroyer started out, when I was about ten.
A dirty great chunk of 4x4 and lots of sawing, chiselling and planing.
Under my Master Carpenter Grandad's supervision of course😉
Just saying hello
Last one is warship
But not anyone in particular
Never done the top deck before so learning before I build
Just saying hello
Welcome aboard ,you'll soon find the site an endless source of information and idle banter, enjoy and make the most of it.
Cheers Marky👍
Just saying hello
Welcome aboard Sailor👍
I agree with Martin and Pete.
Please post your Fleet in your Harbour.
We'd all like to see your boats/ships😊
Good luck with your move, whenever it becomes possible!
Just saying hello
Hello Mike.
I agree with Martin. It would be good to see what you have built.
Welcome.
Peter.
Just saying hello
Welcome to the site Mike.
Looking forward to seeing some photos of your models.
Good luck with the move, i hope it will go forward smoothly.
Just saying hello
Just a quick post to say hello
I have bought a bungalow near to queens park and hoping to move in by end of June
If current situation let’s me
I am a driving instructor but over the last 4 years I have built about 8 boats
Hope to speak soon
Mike
Gostado por Robert 87 and RNinMunich and
