blog write up
Iniciado por Rogal118
7 replies 12 gostos Última atividade: há 7 anos
blog write up
Only just seen this. So when you’re creating/editing posts, they’re regularly saved as drafts. This happens on both desktop and mobile. Mainly so you don’t lose everything if your computer crashes. As a result you can switch device like you’re wanting to. Any pending posts will pop up when you login on the other device. As for how long... I think drafts are kept for up to a week.
Stephen
Gostado por Rogal118 and Martin555
blog write up
yes sounds good to me, i will give it a go
i was just afraid of making a mess and posting blank pages or something stupid, but while folks are laughing at me everyone else is left alone. lol
Roger
Gostado por Martin555
blog write up
Hi Rogai118,
As the other guys have said it is possible.
as soon as you have logged on you can edit and add text and photos on your laptop or iPad.
I also think you can log in on both the Laptop and iPad at the same time if you like.
blog write up
I do not think you can save in that way but what you can do is write the blog and post. Then go to the ipad, open the blog and edit it. You could then add the pictures.
Personally I write the blog on word and then when I am ready, I copy and paste onto my blog and add the pictures. Entries can be edited whenever you want. I started this after losing all what I had written without any apparent reason.
Peter.
blog write up
Hi,
I know you can post using one device (eg Laptop) and then access the post using an iPad and edit it. So I think you could post the text from your laptop, and then quickly go to their iPad and edit. I’ve done that to correct typing errors. What I haven’t tried is adding pictures as part of an edit. Don’t see why it wouldn’t work though.
Not quite what you were looking to do, but maybe a workable solution.
Graham93
blog write up
hope someone can answer this as i don`t want to try it out and get in a tangle and mess my blog up.
Question?, if i start a new blog page on my laptop could it be saved and then opened on my iPad. i have just remembered that the correct photos to my write up are on the iPad, so it is easier to add the said photos from the iPad. but it is easier to type on the laptop.
has anyone swapped the blog write up half way through,and can you leave it for a few days and carry on later.
Or is everything lost on close down????
Roger
Gostado por fireboat and Martin555 and
