deans marine fire boat for sale
Iniciado por larrywhetton
7 replies 0 gostos 0 seguidores Última atividade: há 14 anos
Hello Nick,
That's better never did like cryptic names......
You seem to no all the tech stuff its all a black art to me.
I am ex building trade contracts manager now 76 years old so a little rusty on tech stuff ......
will drop to £75 if collecting ...cheers LARRY
larry whetton
My Name is Nick and I live in Witney, about 12 miles west of Oxford. I worked for a while in Bristol as an Aeronautical Engineering Lecturer at Bristol College but I now work as a civil servant teaching the Army Helicopter engineering.
I guess then that something like some 3500 mAh NiMh 7.2 batteries and a 20 or 25 amp ESC should do the trick? I may have something like that spare as I am going to convert my Robbe Magin 1 speed boat to brushless. That currently uses 2 7.2 3500 Batts in series so the ESC should be able to handle it, although it is water cooled so may have to re-thing that. I already have the RC equipment as I have just bought a 3 channel 2.4G set for it (although with a 3 channel I used the 3rd channel to power a pump for a working monitor?
Would you be willing to drop a little on the price for collection?
HELLO ,
HERE IS PHOTO OF INTERNAL LAY OUT.
As I said it has 550 motor , it is bit over powered ,
it use to have 400 ESC 20amp 7.5 batt. would go back to 400 speed
for a better scale speed ......I made the change for my son who wanted a speed boat .
but got fed up with boat so back in my collection ....hope this helps .LARRY...
ps WHAT IS YOUR FIRST NAME AND WHERE IN OXFORD AREA DO YOU LIVE...?...
larry whetton
Quite interested in this. Loks like there would be enough room to install a pump and maybe get a monitor or 2 working? I am a relative novice in regards to this time of RC boat so what rating ESC do you recommend and what battery set up. I would obviously be looking at something with a relative scale speed not like the brushless racers I am currently running.
hI yes still on sale , none working moniters cheers larry.
larry whetton
Is this still for sale and do the monitors work?
deans marine fire boat is still for sale now reduced to £80
need space for new project cheers Larry.
larry whetton
I have a DM fire boat for sale , 540 motor and rudder servo shaft and prop fitted no ESC OR RADIO
COST £80 POSTAGE AND PACKING £10 OR WILL DELIVER 20 ml of Bristol.
terms cash or cheque thank Larry...
larry whetton
