Steam engine
Seguidores (4)
- RookysailorSilver
- Newby7Bronze
Steam engine
Correct Pete,
I started the project when I was 13/14. Hotspur's Maiden Voyage took place on my 15th birthday August 1966 in the boating pool in Radnor Park Folkestone. We went to stay with Granny & Grandad in Folkestone (where I was born😉) every summer.
I'll put the rest of her history in a Blog or Harbour entry some time!
Steam engine
53 years ago! you must a'v been nowt but a lad.
Cheers, Pete
Steam engine
A Blog 53 years ago!?
Wouldn't have got many likes or replies Pete!🤔
I've just posted a few bits of her over the last 2 or 3 years, when they were relevant to someone's query. She was built from plans I drew up by measuring the Airfix 600 kit parts with a micrometer! Was doing Tech Drawing at school 😉 Had to multiply everything by
8.3333333333333333333333333333333😮
Steam engine
The only problem is that they are all a bit modern for me, apart from HMS Cavalier which can be made as an earlier version than the 1960 plan that comes with it.
Cheers, Pete
Steam engine
Guess 1/48 might be a bit narrow though🤔
The 1/24 plan works out at about 4feet x 4.5inches.
https://fleetscale.com/store/gb/all-plans/708-172nd-arleigh-burke-flight-1-plans.html
Steam engine
Hmmm🙄
How about this? Fastest boat around in 1897😮
The plan
https://www.sarikhobbies.com/product/turbinia-mm1370/
More info😉
https://www.bluebird-electric.net/bluebird_history/Turbinia_Steam_Turbine_Boat.htm
https://paul-stamm-modellbau.de/turbinia-1884-erstes-dampfturbinenboot-der-welt.html
https://www.asme.org/wwwasmeorg/media/resourcefiles/aboutasme/who%20we%20are/engineering%20history/landmarks/73-turbinia-1897.pdf
Would make a fine model and unusual sight on the pond👍
Not essential to build the turbines😁😂🤣
Steam engine
Rick
Steam engine
Steam engine
Steam engine
There are many ways to do this, but I would work from this timing block side.
Steam engine
Steam engine
Steam engine
If I remember rightly the engine you have is actually a stationary twin cylinder vertical with hackworth valve gear (It has sliding blocks and pivots) The lever will need quite a heavy servo as you are trying to move the sliding inlet valve to a different position on the valve block and there is always pressure there. I will see what I can dig out some info on hackworth valve gears but as to the installation not sure. (Ex Model Engineer)
Steam engine
Don't forget to show how the engine, and boiler gas tank and any other necessary gizmos, fit around it.
Then we can see where we might be able to fit a linkage.
Steam engine
I'm a dunce when it comes to steam engines, and gobsmacked by the machines some folks can build. 😮
But servo linkages is more my game, so if you can post a photo(s) of the engine showing the lever, and how the engine sits in the boat, I'm sure we can work something out👍
First thought is to use a linear servo, but need to see how the lever moves.
Steam engine
Rick
Gostado por
A carregar…
