3D Printer
"A goodwill gesture from the makers ..."
There's no such thing as a 'free lunch' Steve😉
Buyer's maxim! Bane of the sales engineer🤔
3D Printer
Just ask the postman LOL!!
3D Printer
The 'loose' filament came with the printer, as did the dog file.
A goodwill gesture from the makers to get you going and ensure the set up was correct.
I have purchased a a reel of filament now and have found a website to print a filament guide.
Cheers Steve
3D Printer
Unfortunately my dog has teeth at both ends LOL!!
3D Printer
Looks like Steve got 'the s****y end of the stick'! The 'Og' 😮
Puzzles me how though.
I've never seen loose filament before, always on reels, and a filament guide to assist in drawing it evenly off the reel. Suggest looking for, or printing?, a suitable reel to wind the filament onto.
3D Printer
3D Printer
Cheers Marky👍
3D Printer
Like the seagull file Marky😁
Again, many thanks for the ship's lifeboats 👍
3D Printer
You are inspiring me to dig my printer out, dust it down, and get it calibrated.
Don't have a real task for it yet though🙄
BTW: Half a dog is better then no dog! 😂🤣
Ok OK I was just leaving anyway😔
G'night all😎😴💤💤💤
3D Printer
Try and get a video of the printer working.
Cheers Marky👍
3D Printer
Where I used to work before retiring (University workshops)we had lots of 3D printers in a lab that students could just put in their files and print
3D Printer
Got the printer on Saturday and set it up with the video you sent me. I'm impressed with the quality and the way it went together.
Like you, I find there is a lot to learn.
Here is a link for the 'cowl vent' https://www.thingiverse.com/search?q=cowl+vent&type=things&sort=relevant
Steve
3D Printer
Downloaded stl file from Thingyverse, re-sized it with Cura, sliced it and loaded it into the printer. Pressed a couple of buttons and 15 minutes later a cowl vent was born!
Still a lot to learn Ed, but all good so far.
Steve
3D Printer
Thanks!
This 3D stuff is fascinating!
If only I knew what I was doing! LOL! Or do I!
Ed-
73
3D Printer
it's about 43 mm!
It's spot on!
I told Cura 43 mm!
And it came out to be 43mm!
73
3D Printer
Steve
3D Printer
Prepare for a ruff ride!
There's a lot to learn!
But, It can be fun!
And very frustrating at times!
But, Don't give up!
Take your time with it!
I recommend a lot of YouTube video's
And as I say "If I can do it, You can Too"!
Cheers, Ed
73
3D Printer
No, what you need to do!
Is use a program called "CURA".
You would download the file.
Which is a zipped file.
You would then need to unzip the file!
I believe windows 10 will unzip the file!
If not purchase "winzip" to unzip the files!
After you have unzipped the files!
Look for them look in the "Files Directory".
You just unzipped!
Here's where you'll find your files!
Now use "CURA" to open the files.
Only open 1 file at a time!
You can then "SLICE" the object in the file.
You just opened!
You will then have the option.
To save the "SLICED" file to you SD chip!
Or if you have the cable attached to the printer.
You can then print to the printer!
Steve,
At the moment I still learning "CURA"!
So, have just learned a few things!
I haven't learned yet how to scale!
But, I'm learning every day!
Cheers, Ed
73
3D Printer
The files on Thingyverse, can you download them and put them straight into your printer? If so, I assume there is a way of changing the size of the item you want to print?
Steve
3D Printer
3D Printer
The PLA supplied is rolled up and not on a reel. It got tangled and jammed around the frame. The printer carried on, but with no PLA, so poor old Deefer has only got half a head.
I paused the print and got the PLA going through again but of course the printer started where it left off, so it all went to raspberry juice.
On the plus side, I am very pleased with the finish.
I was going to print it again but now I know I have everything set up correctly, I am going to download a simple file (I have in mind a cowl vent).
Overall I am very pleased.
3D Printer
I'm impressed with the quality of the parts and and the tool kit - even cable ties and a side cutter - and they supply a quantity of PLA and a test programme - the 'dog'.
It's currently merrily printing away and is really quiet.
So far. so good!
3D Printer
Rick
3D Printer
I'm glad you found the video enjoyable!
I followed it to the letter!
And was able to assemble my printer with no problems!
At the present time I'm learning.
How to use and calibrate the printer!
There are two programs that are used!
1. Cura which is a slicing program!
2. Autodesk Fusion 360! for designing things!
But, there's a website called "thingyverse"!
Here is where you can find already made files!
You download a file you like.
For example your ships wheel!
I haven't found that one yet!
But, you could use Autodesk Fusion 360.
To design your ships wheel!
I'm not up to that yet!
But. I'm learning as I go forward!
Cheers, Ed
PS. You can google both programs.
And you should be able to download them!
73
3D Printer
My question is if I wanted to make a ships wheel where would I look and what do you look for.
How easy is it to program the pieces you want.
Rick
3D Printer
3D Printer
Steve
3D Printer
Thanks for your advice. I've just ordered the Creality 3 Pro, or V2. As you suggested Peter, it seems the improvements are worth paying the extra £50. There is an awful to of help on the www, particularly YouTube.
I will let you know how I get on.
Steve
3D Printer
Thanks for that. I have done some research and it seems that the Creality 3 is the one to go for. There is plenty of help on the www.
Peter
Thanks for the info. I'm on the point of ordering the V2. I'll let you know how I get on
Steve
3D Printer
I think the Creality 3 printer.
Is a good choice for a starter!
It took me 2hrs 30 mins to assemble it!
I use some files from Thingyverse!
The most important thing is the keep the building board leveled!
There are more elaborate printers out there!
Do some research!
Find what you like in a 3D printer!
Cheers, Ed
73
3D Printer
The Creality Ender 3 is a very good starting printer which Ed has bought. He is having a lot of fun with it and started printing samples as soon as he had assembled it, which did not take him long. The cost is around £200 or less now as it has just been replaced with the V2 version which has a lot of updates done to it. I have just purchased this machine and expect its arrival soon. The V2 Ender 3 is around £250 but I think the extra would be worth paying now as some of the upgrades, such as a glass table, are essential.
Peter.
3D Printer
Ed (Figtree) has just taken the plunge.
Have a look at his experiences in his Blog here-
https://model-boats.com/76902
3D Printer
I am thinking of purchasing a 3D printer, of which I know very little about.
I don't want a cheap and cheerful one but I don't want to spend an arm and a leg.
Any advice would be most welcome.
Thank you.
Steve
Gostado por
A carregar…
