PT Boat Overboard Discharge pipes
Iniciado por CB90
5 replies 5 gostos Última atividade: há 6 anos
CB90,
Check your PM's. I sent you some scans.
Roy,
ELCo blueprints show a different number of bilge discharges per side. I will need to look fo the cockpit drain schematic to see how those were laid out as well as any other discharges. Nothing is somple. LOL
Jonathan
Hi ToraDog,
An ELCO 80 103 class, early numbers 103 to 109.
have found a good plan of the 109, but only shows one side of the boat. there seem to be many small ports on the side, see pic.
Regards Roy.
Regards Roy
CB90,
Are you looking for the discharge locations for the 103 class? if so, which boat #. They changed.
Gostado por Martin555
Found this but it does not show all the drain holes of the Plan.
Regards Roy
Gostado por MouldBuilder and Martin555
Hi All,
As per Diagrams the overboard discharge pipework is shown, does any body know if they were equally positioned on both port and starboard sides of the PT boat?
Most Pictures they cannot be seen, and plans I have only show starboard side!
Many Thanks
Regards Roy
Gostado por Ianh and Martin555
