GoBilda 300 degree rotation servos
Seguidores (1)
At 6 volts here's how they compare torque wise:
Gobuilda - 21.6 kg/cm
Hitec 755 - 13.8 kg/cm
Hitec 815 - 24.7 kg/cm
Futaba 3802 - 14 kg/cm
The Futaba at 14kg has always been enough for my 1 Meter boats, so the gobuilda should be more than adequate .
Good post, I also have recently discovered these "gobuilda" servos. I was looking for a sail servo for my US1Meter boat and saw these. They have very high torque and are much smaller than my typical Futaba or Hitec sail servos. I can adjust to the 300 degrees with my DX6, no problem.
Have not sailed with yet so time will tell if they last under load.
Joe 😎
Recently I found GoBilda servos. Available in standard or high torque versions, these units can be ordered in two different configurations, 1) as a 300 degree rotation proportional servo, and 2) as a 360 degree rotation servo with proportional speed and directional control. Here in the States they run around $28 US. I found that they can be ordered from third parties or direct from the manufacturer. I have used 8 on my current build and am really happy with how they worked. The shop I ordered them from had hardware that allowed easy direct connection between the unit and the servo. NO gears, ect. Here is a link to the manufacturer's page: https://www.gobilda.com/servos/
No, I do not own stock in the company, sell the servos, or otherwise, I just like that they are available.
One caveat: most radios will require the use of a servo stretcher in order to get the full 300 degree rotation, so that cost should be figured in to the servo cost as well.⚡
Gostado por
A carregar…
