I'm getting ready to build my Trent class Lifeboat and Humbrol paint
Seguidores (9)
- RookysailorSilver
- mturpin013Bronze
- Newby7Bronze
I have seen your latest build log. It looks really good so far.
The one I am having difficulty with is Dusseldorf. Your last post was a redirect to pictures. I have never managed to open it. Thanks.
Peter.
Why did Model Slipways stop producing. Is there a chance somebody will take over and produce them again.
Peter.😉
I was following your build log on Dusseldorf but never cold open the link posted on your last entry. I have just tried the links you have just posted and still cannot open them. I must have something blocking me.
Peter.
Did you say you were thinking about doing a tyne class ?
It is Peter (Mould builder) that has the Tamar.
Martin555,
I have just come across this new Forum Model Lifeboat that is just for model Lifeboats only.
http://www.modellifeboat.com/forum/index.php
Fred
Perhaps you mean all three of us ME, MYSELF and I LOL!!
Sorry, got me Ps mixed up🤔
Sit down, put ya feet up, we'll pay for you!😁
Me ???
I use the cheapies off of ebay.
The only thing i do is when i first get them i use a drill with a felt pad fitted and some chrome cleaner and i polish the needle tips.
Then the lightest smear of vasoline on the needle before spraying, this helps to prevent tip dry.
And i find they work great, from fine thin lines to wider sprays.
I have only had one Airbrush that was pretty useless so i striped it down and kept the useful parts for spares.
Quite true Doug, we paint our houses, / roofs etc with acrylics and nothing will touch it. Just painted my roof with acrylic. I use Reeves artists acrylic for lots of model bits, including the insides of hulls (and straight over f/glass nice and thick) never had any come off,- totally waterproof. Even cars are being sprayed with the new auto acrylics now as they are much safer on health and environment.
I use Reeves metallic acrylic bronze on my plastic props (which spin at 8000rpm in the HSL for eg) and it hasn't budged.
Sheesh, pints of paint!
How damn big IS your boat Bruce? Are you building a full size?
I used to use a gun like that to spray cars.😮
If I were you then I would just go for the nearest Fed Std paint you can find in this chart.
https://hobbylandbg.com/colourtable
I don't think you'll need anywhere near a pint for most of the colors as they are only for detail work.
Doug 😎
PS Not using acrylics on boats is rubbish. When fully cured they are totally waterproof.
If you're worried you can always seal it with a clear lacquer anyway.
I use a larger spray gun tha sprays 2- 4 inch pattern I find smaller air brushes for large areas too time consumming. and get blouchy results..I'm using a Iwata baby seriers LPH-80-102G with a 150ml cup and a 70ml cup on my other gun. it works better for me anyways. buying that many cans is way to expensive, I buy most of my boat paint from Total boat for $18 for a pint polyurethane marine topside paint. and it will hold up to water, where most of the model paints tell you not to use it on boats that wilbe used in the water especially the acrylic paint the are water based.
total boat http://www.totalboat.com/product/wet-edge/
https://www.amazon.com/ANEST-IWATA-lph-80-124G-Spray-Series/dp/B001Q8WNH8
The reason i'm looking for some of these colors is the boating people don't have the colors i need and international orange for this boat is different than USA orange so i'm looking for the color code so i can get it made at one of our auto paint stores.
I do appppricate your input a lot thank you
I use an Airbrush to spray all my model boats big or small.
When working on a big Hull's i mix up plenty of paint and just keep topping up the Airbrush.
For the large areas i use the Airbrush with the glass jar attached.
I use the the small tins of Humbrol paint.
I hope you will do a Build Log.
I've been through the model paints and I've found this:
Humbrol Tamiya RAL Revell
18 Orange X06 2004 32130
19 Signal red X07 3000 32181
15 Midnight Blue X03 5022 32152
130 White XF02 9010 32301
56 Aluminium XF56 ---- 32199
67 Tank Grey XF63 7024 32178
85 Coal black X18 9005 36202
40 Pale Grey --- ---- -----
I got the cross references from the attached weblink.
One thought that I had, is that you could get a bunch of paint testers made up at home depot or lowes paint dept's which would be cheaper than using the model paints (they would use the RAL numbers). All you would need to do is put them through an airbrush and a coat of varnish to protect them.
Good luck
Bill
I found this online, there are a few excellent recent/ongoing lifeboat builds here that are worth having
A look through.
These are the Paint Codes from the RNLI Engineering Section for the colours used:
BS381c
Lifeboats Blue: Oxford Blue 105
Lifeboats Yellow: Bold Yellow 363
Lifeboats Red: Rail Red 539
Lifeboats Orange: Orange 557
Bill
Nerys
Thank you
If you can give the humbrol numbers, we should be able to match it to the RAL numbers which the real boats would be painted in.
Bill
What are you using to paint larger RC boats that match Humbrol paints? I'm in the USA please don't hold that against me. LOL
Thanks in advance.
Bruce
Gostado por
A carregar…
