Sound
Iniciado por Newby7
5 replies 7 gostos Última atividade: há 6 anos
Sound
The stiffer the box, the better the sound. I’d suggest you try the cardboard box first. If it sounds OK, then there’s no need to replace it. If you do use it then Martin’s advice is sound (pun intended😂🤣), it needs to be waterproofed.
Graham93
Gostado por Martin555
Sound
Hi Ron,
Personally i would make it out of wood or plastic.
Cardboard box would work but you should completely coat it with paint or varnish or even resin to waterproof it.
Sound
The RAM product, tugboat horn, came with a cardboard box to house the speaker. Is this a good idea?
Sound
Thanks Graham the information will help to pick a good spot for the speaker.
Rick
Sound
Hi Rick,
A speaker vibrates air in front if the speaker cone and behind it. You need to stop the air that is moving at the front mixing with the air that is moving at the back. If these two vibrations mix, you don’t get much sound out of the speaker. Mounting the speaker on a very large (infinite) panel does that as the air vibrating at the back can’t travel round the panel to the front. Unfortunately fitting an infinite sized panel in a model boat ( or anywhere else) isn’t practical, hence the need to mount the speaker in a box to stop the vibrations from the back mixing with those from the front.
The hull can act as the box. You just need to work out where you can mount a panel with the speaker on it so that the back of the speaker is sealed, and the front is open to let the sound out.
As for size, the general advice would be ‘as big as possible’😀 I’ suggest something like 70mm diameter. If you can fit that in. As you are wanting to generate steam sounds, which tend to be higher frequency, you might get away with something a bit smaller.
The link should show a photo of the speaker I fitted in my rowing boat. ( Scroll down to ‘radio upgrade’) It is positioned under the foredeck which is quite a small space but it works well. You can hear Bionic Bill singing right across the lake. 🤣
Graham93
Gostado por Peejay and RNinMunich and
Sound
I've looked at steam sound units to put in my puffer but wondered about the speaker.Would it need an enclose box or sit open in the hull.The other is what would be a good size for a speaker.
Rick
