Adhesive's
Seguidores (8)
- mturpin013Bronze
- Newby7Bronze
Adhesive's
Adhesive's
https://m.youtube.com/channel/UC2rzsm1Qi6N1X-wuOg_p0Ng
This is to his main listing....go through his list to find your interest.
CaptLarry
Adhesive's
CaptLarry
Adhesive's
CaptLarry
Adhesive's
Cheers, Nerys
Adhesive's
An added comment, do not use CA or super glue for adhering windows to frames. It will fog clear styrenes.
White glue( PVA) for wood to wood, slow but old school.
Lastly, as mentioned, try to understand the stresses that your joint will be under and plan your glue to deal with it accordingly.
Adhesive's
Z-Poxy 30min 8oz Epoxy Resin PT39 for GRP to Wood
Deluxe Materials Aliphatic Resin - 500g (Economy) S-SE10 for wood to wood
Zap Formula 560 Canopy Glue PT56 for windows
Deluxe Materials Plastic Magic 40ml S-SE54A for styrene
That's what I use hope that helps
Adhesive's
I think you have opened the floodgates now. LOL!!
You will get some great advice regarding adhesives.
So i will add to your request, I use two part epoxy for wood to fibreglass (Araldite).
Good luck with your Tug Portgarth.
Will you be doing a build log ?
Adhesive's
I use Gorilla wood glue mostly.
"Goop" is another I use when cured remains flexible joins many materials together.
Two part epoxies (5 min) may be used to join parts.The epoxy heats when curing and may distort items in curing.
I believe La Pages has a canopy glue that dries clear for windows .
Hope this helps some.
Rick
Adhesive's
I shall be starting to build my model tug which is mmm Portgarth
the question is this is my first big build and I am not sure what glues to use such as wood to fiberglass hull and wood to wood also when I put the windows in what material should i use and glue for fitting them any help please
Gostado por
A carregar…
